Extra Lights
Old Jan 10, 2004 | 06:23 AM
MRDS650's Avatar
Canadian and Proud of it !!!
Default Extra Lights
Hey: Guys
I bought a set of 55 watt driving lights and was going to hook them up for better night ridding for the MLK weekend at Glamis. I was thinking of hooking them directly to the battery and operating them with a extra switch because I remember something about the stock system not being able to handle this type of draw, on a 2000 DS.
Any idea or suggestions.
[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jan 10, 2004 | 10:20 AM
BajaIowa's Avatar
When they talk about not being able to handle the draw it doesn't matter where you hook them up. It will drain the battery because the charging system won't be able to supply the juice to the lights and recharge the battery from starting the quad. That is what they say, but I switched my baja lights to 55watts and the stock headlight is 55 watts and I have never had a problem with the system not keeping up. I don't let it idle a lot and try not to kill it a lot. Keep in mind that I don't ride at night for more than an hour or so at a time.
Justin
Old Jan 10, 2004 | 10:32 AM
CdaleUSA's Avatar
I mounted 2-50W lazer star lights on my brush gaurds and ran all the wiring from the battery and put in a switch and have never had any problems with it running all stock plus the two extra lights. I checked the manual and it is a 290 watt system and I'm using about 260-270 when all the lights are on and I do a lot of night riding.
Tom
Old Jan 10, 2004 | 11:27 AM
MudStud's Avatar
I run a 50/100 main light then dual 50 watt trail tech lights.
The DS uses 27 to power the motor and electronics.
The Tail light is 8w on and 12w stopping.
Mine works fine...
Old Jan 10, 2004 | 11:37 AM
lilnotts's Avatar
i'm running two 55w lights where the baja lights would be, LED bulb in the taillight, i was using the 00-03 headlight and had no problems, i now have the 04 headlight and i've no problems but haven't used it much yet
Old Jan 10, 2004 | 12:41 PM
JSsDS's Avatar
I put a set of 50w laser stars on that work real well for pointing light where you aim the handlebars.
I used a relay that will only turn the 50 watters on when I hit the high beams, kinda nice not to have to mount a switch and alot easier to operate that way. Its simple to wire and I can explain if anybody wants to this setup.
If you do install extra lights it is best to take your power source (or common) directly from the battery. 100watts = 7.7 amps, that is too much for the factory wiring to handle and it could damage it.
speedbuff
13
Nov 11, 2020 10:16 AM
panicmanic
Sep 28, 2015 12:59 PM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
