high beam, instrument light and AWD linked?
Plowing snow tonight with my 2002 SP500 when my high beam light quit, so I headed for the garage. The bulb looked fine and I checked inside the pod for loose connections/damaged wiring but found nothing. I threw the bulb in my pocket and put every back together. Went back to plowing and found that the instrument lights and AWD don't work either. Is this all a coincidence or do these items share a common power source? I've checked and re-checked the wiring but everything seems OK. Low beam, tail light, starter, etc. work fine. Anyone have experience with this problem?
Thanks
Thanks
i also have had that problem (sort of) the high beam switch kill switch assy isnt too weather proof you have to take it off and have someone take it apart that is used to working with springloaded stuff clean it and try that or else buy a new switch
jayking232003
Jul 23, 2015 05:48 PM
micheleLeigh
Technical and How-To Articles
Jul 19, 2015 07:32 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
