is 75 lbs of compresstion good?
Old Jan 11, 2004 | 12:27 PM
loveotride123456789's Avatar
Default is 75 lbs of compresstion good?
is 75 lbs of compresstion good? for an 86 honda 250es big red
thanks
Old Jan 11, 2004 | 12:44 PM
sickmojave's Avatar
I think you would be lucky to get it started with the compression that low [img]i/expressions/face-icon-small-shocked.gif[/img]
Old Jan 11, 2004 | 01:38 PM
hondabuster's Avatar
check valve lash, if the valves are tight, youll have poor compression.
Then check compression again.
If no change then Try a little quirt of oil in the spark plug hole, then spin the motor, with out the plug installed, to distribute the oil. Then do the compression test, if its better, then the rings are leaking.
Old Jan 11, 2004 | 07:42 PM
dragracer789's Avatar
lol thats about how much a weed wacker should have bud... To low
Old Feb 4, 2004 | 01:54 AM
atcpowermadman's Avatar
the 250es and 250sx are basicaly th esame motor btu the factory compression ratio is 6.2:1 witch isnt alot to begin with i ahve 3 motors for my 2 250sx's and when i tore my old motor out to rebuild it it ran find btu only had abotu 68lbs of compression but i also reveed the **** out fo it till i put 22inch tires backon it a=fter i rebuilt it and threw the razor;s on my 200x .
Old Feb 4, 2004 | 02:21 PM
ThrashAndCrash's Avatar
I hate to correct you but the factory compression Ratio is 9:1 on the 250ES, but you are correct they are basicaly the same engine because the 250sx came stock 9:1 also.
'Lovetoride' No 75lbs is not good.....if for some reason it does run; it sure is not as STRONG as it should be!!!
Old Feb 4, 2004 | 03:55 PM
Should be 156 PSI + or - 14 psi
Nondem
Feb 22, 2020 12:20 PM
Unzzy66
Jul 11, 2015 10:01 PM
cornermike
Jul 8, 2015 11:44 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
