Hesitation on my Wolvy
Old Jan 11, 2004 | 09:37 PM
gdcharlton's Avatar
Default Hesitation on my Wolvy
I have a hasitation with my Wolvy. It does not happen every time I start my bike. When it does happen, it idols fine, but when i go to give it some gas it will not rev any higher, and bogs right down then backfires.
I am thinking a piece of dirt might be in the carb. The airbox is clear, and free flowing.
Any suggestions!!??!!?? It is suppose to snow tomorrow so I want to be able to Plow / Play, so any quick fixes that might work will be appriciated.
Thanks
Old Jan 11, 2004 | 10:35 PM
LotusPosition's Avatar
Have you checked the parking brake rev limiter switch? If you have, then I would check the carb bowl for dirt, it is a common thing.
Old Jan 11, 2004 | 11:21 PM
gdcharlton's Avatar
holy crap...I am an idiot!!! I forgot about the park break rev limiter. Thanks man!!!!
Now if it is stuck on. Where is this switch located??? and/or, what would have to be done to disengage it?
Thanks again
Old Jan 11, 2004 | 11:25 PM
You can either try lubing it and working it back and forth........or just trace the wires down the frame and disconnect the d#$@ thing. Just don't leave your park brake on.....
Old Jan 12, 2004 | 01:01 AM
CTATV's Avatar
yea i had that problem when i had mine for a while on and off and eventually it just stopped. it wasnt the parking break sensor, the break doesnt even work, its a total piece of junk anyways.
Old Jan 13, 2004 | 02:22 PM
BigBearFX's Avatar
my parking break dosnt work eiher id like to disconect it.
Old Jan 13, 2004 | 06:03 PM
95Wolverine's Avatar
If removing the switch, do a search under autohors for my name. I did a post a while back on how to remove the parking brake switch on either a warrior or a wolverine (I do not remember which and they are the same). I also did a quick note on the parking brake block off plate being the same as a warrior. That is all that is required to totally remove the parking brake system.
Let me know how it goes.
Ride On.
hueby
Nov 6, 2015 11:34 AM
house1
Aug 9, 2015 10:49 PM
Austins
1) Engine problems..
Aug 9, 2015 02:28 AM
D-Hagz
Jul 4, 2015 02:19 AM
ScoobyDFW
Feb 9, 2001 06:06 PM
