Low Gear Linkage on an '02 P650
Old Jan 12, 2004 | 05:05 PM
txhitman01's Avatar
Default Low Gear Linkage on an '02 P650
I need some help with my linkage. I know I need to adjust it, but I am not sure how to go about it. I can shift into low and it stays. I can give it some throttle and it will go, but when I let off the throttle, I knocks/clanks like it is trying to slip out of low gear....it doesnt, but it is trying. How do I adjust it to take care of this?
Old Jan 12, 2004 | 05:36 PM
NovaKaw650's Avatar
You need to adjust the link that goes from the bottom of the shifter to the tranny. It's been so long since I did it that I can't remember whether it needs to go longer or shorter. A trick to get it set right is to put the machine in reverse with the key on, adjust the link until the reverse light goes out, and then turn the link the other way until the light just barely comes back on. That usually gives a perfect set-up.
Old Jan 12, 2004 | 06:35 PM
txhitman01's Avatar
Cool. I'll try that tonight. Thanks.
patrick.oc123
Sep 15, 2015 02:45 PM
bigbear350quad
Sep 11, 2015 12:40 PM
Steeldon
Sep 9, 2015 09:38 AM
awer1968
Sep 8, 2015 11:02 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
