OT FORD BRONCO 351
Old Jan 20, 2004 | 12:26 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
Default OT FORD BRONCO 351
My oil gauge has been showing declining oil pressure over the last 1000-2000 miles. (strong runner I might add)
The needle is about 1/4 over from the left. (it used to be about 1/2-2/3)
I am fairly new to this vehicle and fords in general. Where would you start looking?
1990 bronco 351 efi 150,000 miles
I just figure its a bad/clogged oil pump......
Help!!
Old Jan 20, 2004 | 12:51 PM
Specta's Avatar
You need to run a mechanical oil pressure test. Remove the oil pressure-sending unit and install a mechanical gauge. Almost any repair shop can do this for you. Your Bronco has a "module" behind the instrument cluster that tells the OP and Temp gauge where to point. The needles are not really what is going on. When you turn on the ignition there should be a red engine light, if there is a problem the light will come on. They call these idiot gauges. They are programmed to point where ford wanted them to to make the driver comfortable.
Old Jan 20, 2004 | 02:34 PM
TIC's Avatar
TIC
Had a 92 OJ bronco, with the 351, my oil pressure gauge drove me crazy moving up and down.
Normal oil pressure to low pressure.
Just like the post above mine. it was the oil sending unit or the oil pressure deal that the gauge runs off of. it was like 56 dollars to fix, parts and labor
Old Jan 21, 2004 | 01:11 AM
Chris142's Avatar
I agree. The stock guages are a joke. You can pick up some cheapies for less than $30.00
$30.00 that may prevent $1000's in damage if something did go wrong.
Old Jan 21, 2004 | 02:24 AM
Bing's Avatar
Super Quad Patrol
i hear ya
30$ sounds like a cheap fix
where can i find a cheap oil gauge?
Old Jan 21, 2004 | 02:59 AM
Mudfoot's Avatar
Summit racing.com
They kick a**.
Good luck Bing
Old Jan 21, 2004 | 03:36 AM
LethalAudio's Avatar
nothing really to add but to comment on the gauges...yes they suck massivly.
but just to kinda remanice....if you want a to keep your mpg up on your broc, dont EVER get ANY engine mods done. I sank about 3k into mine and it wasnt even extreme in any way. No turbo or anything. i went from about 19mpg to 7mpg. It sounded like a drag car when i got it back...literally...it was beautiful...and loud....8-12"s, 3 amps, 2 comp systems...no caps...only a 250amp ambulance alternator under the hood.....God I miss that truck. But i enjoy not having to spend 40 bucks a week to keep gas in it. Id give just about anything to have that truck back, that thing had power like you wouldnt believe. But mine wasnt efi, it was an 87 so it was carb'd. But just to sum up...get new gauges...in the years I had that thing...they were rarely accurate on any measurement.
Sorry to ramble, but I miss my baby. [img]i/expressions/face-icon-small-sad.gif[/img]
Old Jan 21, 2004 | 12:04 PM
Specta's Avatar
Our Bronco is an 89 5.8L. Lunati Cam and valve train, BBK Racing throttle body, JBA Shorty headers, Gibson exhaust, K&N air filter, and a Ford 7.5L fresh air intake. It gets the exact same gas mileage as it did stock (crumby) but it does run quite well.
mdigitale
Aug 6, 2015 12:35 AM
Jun 20, 2015 09:01 AM
Mike Chero
Dec 12, 2002 11:11 AM
Warthog
Nov 21, 2000 04:15 PM
B777
May 10, 2000 11:21 PM
