Oil Pressure and Oil Type
Old Jan 22, 2004 | 12:30 AM
ScoobyDFW's Avatar
Default Oil Pressure and Oil Type
I recently installed an oil pressure gauge and oil temperature gauge. I've been trying different oils. The latest oil I tried was Klotz 15W50 MX4. I do not recommend anyone use this oil! The oil pressure would drop to very low pressures as soon as the oil came up to temperature. Had I not noticed this and changed the oil I might have hurt the motor. I had more Klotz so I put the same type back in and the pressure was a little higher but still dropped way off at temperature. I went to walmart and bought mobil 1 20w50 vtwin oil. the oil pressure now was higher and didn't drop as much at temperature, even after hard riding. i'll never use klotz again. i've talked to other people who have had broken cranks due to klotz oil.
but if you don't care about the motor, then there might be an advantage to such an oil - faster reving and more power. i'd rather protect the motor.
(also, when i drained the klotz oil from the crankcase it rushed out like water!)
Old Jan 22, 2004 | 12:40 AM
CountryJoeGlass's Avatar
dang that sucks, glad you caught it scooby before major damage! thanks for the info!
Old Jan 25, 2004 | 06:44 PM
ScoobyDFW's Avatar
Old Jan 25, 2004 | 10:26 PM
VEGAS650's Avatar
Scooby, have you tested Redline?
I just put an oil pressure gauge and a water temp. gauge in the Pig, but if you have already tried it I'd like to know how you liked it.
Old Jan 25, 2004 | 11:09 PM
1BigDSRider's Avatar
Scooby, what gauge are you using?
Old Jan 26, 2004 | 12:42 PM
ScoobyDFW's Avatar
i haven't tried redline recently.
i use a sunpro mechanical oil pressure gauge and an autometer mechanical water temp gauge for oil temp.
Old Jan 26, 2004 | 02:53 PM
Do you have any pics of them? How hard were they to install?
Old Jan 26, 2004 | 03:10 PM
ScoobyDFW's Avatar
not sure if i have any pics.
the install is not hard, both gauges come with the fittings that are needed.
the water/oil temp gauge has the correct fitting that screws in where the magnetic plug is on the oil tank.
the oil pressure gauge has the correct fitting to allow teeing into the oil pressure switch. it comes with teflon hose.
Old Jan 29, 2004 | 05:13 PM
ScoobyDFW's Avatar
Old Jan 30, 2004 | 12:43 PM
muddeep's Avatar
hey i was just wondering if u have tryed rotella deisil oil. i started using t after i talked to a bunch of other guys and i have no problens with it
