Help! Honda 400EX 2003 Electrical Problem
Old Jan 24, 2004 | 12:26 AM
joemay's Avatar
Default Help! Honda 400EX 2003 Electrical Problem
I have good full charge battery. Good fuse. No neutral light, no head lights, nothing. Anyone have any ideas where my problem might lie. Ignition Switch, Neutral Switch?????
Anyone have any ideas that I can try besides calling the dealer.
Old Jan 24, 2004 | 07:50 AM
ATVGuruDude's Avatar
Go to the dealer??? [img]i/expressions/face-icon-small-confused.gif[/img]
Old Jan 24, 2004 | 10:25 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
There isn't an easy answer. You are just going to have to trace out each wire and find out where the power interuption is.
Old Jan 24, 2004 | 11:24 AM
dzzy's Avatar
It's not your neutral switch if your headlight doesn't work either. If your battery, terminals, and subframe stuff checks out, I would go to the ignition swich connector(s), and make sure they're plugged in (as well as all the other connectors). Power to the ignition switch from the battery has always been either a red or maybe red\white wire with Honda. Put a test light on that wire and see if you have power. If not, the problem is between the red wire and your main fuse, or a battery connection, as bartlett pointed out. If you do have power at the red wire, you need to inspect the ignition switch. Check for any wires that may have chafed or wore through at the point where the harness has to move, like when you turn your handlebars.
3quadbob
Sep 18, 2016 09:46 PM
DTroyer01
Jul 3, 2015 07:34 AM
'86 TRX125
Jun 6, 2015 07:43 PM
lovinhonda
Jan 25, 2000 09:17 PM
roktoy
Aug 25, 1999 04:37 PM
