sport 400 recoil
Old Jan 24, 2004 | 10:48 AM
xr100r's Avatar
Default sport 400 recoil
I need some advice about a 1999 Sport 400. The recoil got stuck the other day.. it pulls out about one foot, and then stops; (the electric start hasn't worked in years.) I'm wondering if it's a complicated thing to fix, or can I just remove that right-side cover, straighten the snagged rope out, and replace the cover? I'm no mechanic! is this just a straightforward process, or will I be in over my head, once I unbolt that cover?
Old Jan 24, 2004 | 11:47 AM
Clapper's Avatar
I haven't done much to my Scrammy since I got it except jack with the starter and recoil.(and ride, of course) But I can tell you that it is not a very difficult task to take the cover off and access the recoil. Not a big deal and not too complicated. I am no pro by ANY means. I am going to be doing it agian soon, as I have a problem with the recoil not retracting once the machine is warm/hot.
Does anyone know if I should grease the recoil or get a new spring? If so what grease?
Anyway, not a big deal. If you feel comfortable changing brake pads or just minor maintenance on a car or bike you should be okay, IMO.
Old Jan 24, 2004 | 07:22 PM
99sport's Avatar
I went to the dirt drags last saterday and the first pull on my sport and the handle and rope where still in my hand when it started.LOL It did nt take but about 15 minutes to fix it.Take the cover off,flip it over and you will see the starter.Take out the center bolt and it all will come apart.Make sure you put the leg back in just as it came out.Its pretty simple
Old Jan 26, 2004 | 12:08 PM
luvit's Avatar
It should not be hard to fix. I just fixed one and I'm willing to sell it cheap. It works fine and I've tested it on my 400. Let me know if I can help you.
Old Jan 26, 2004 | 11:14 PM
xxxracerxxx's Avatar
it sounds like the ratichet dog you just need to take the cover off and there will be a little piece of metal you just need to push it in this happens to me on the trail a lot if you lube it it will work better
Sep 30, 2015 01:37 AM
Hack714
Sep 26, 2015 08:11 AM
cboler9
Sep 24, 2015 08:35 PM
kampswas
Sep 23, 2015 05:05 AM
Hack714
Sep 20, 2015 05:54 PM
