99 Scrambler motor and tranny into a 95.
Old Jan 24, 2004 | 01:56 PM
Troyer23J's Avatar
Default 99 Scrambler motor and tranny into a 95.
Hey. Would it be a problem using the motor and tranny from a 99 and putting it in a 95? I dont know if it matters with the 99 being a concentric drive.
Old Jan 24, 2004 | 03:39 PM
Hozed's Avatar
i think the concentric drive set up was in the suspension... not positive tho...
Old Jan 24, 2004 | 04:13 PM
Troyer23J's Avatar
So the motor and tranny should be all interchangable then...
Old Jan 24, 2004 | 06:44 PM
700quadman's Avatar
The 99 has a concentric drive transmission - completely different. Engine will interchange but not the transmission. I own both...
Old Jan 24, 2004 | 06:47 PM
Troyer23J's Avatar
So i can buy a non-concentric tranny and bolt it up to the 99 motor and that would work.... Ok. Thank you very much.
Old Jan 24, 2004 | 06:49 PM
Troyer23J's Avatar
How about the 250 tranny, is that the same as the 400?
Old Jan 24, 2004 | 06:56 PM
700quadman's Avatar
That would work. If you have a 95 scrambler, you already have a non-concentric trans. 250 and 400 transmissions are the same. In fact, almost any non-concentric transmission would work, except shaft drive models like the Sportsman.
Old Jan 24, 2004 | 11:23 PM
Troyer23J's Avatar
The gears and everything inside the 250 tranny and the 400 tranny are the same?
Old Jan 25, 2004 | 03:51 AM
700quadman's Avatar
I'm not sure about the innards. i know the cases are the same. 250 Trailblazer transmission cases are the same as the 400 Sport cases, both are two wheel drive. If you have a 4X4 Scrambler, you could put a hi-lo transmission in it out of one of the utility 4X4 models. Bolts right up. Instant wheelies...
quickwhips
Sep 2, 2015 06:53 AM
Haakon
Aug 24, 2015 01:54 PM
raceware
Jul 30, 2015 06:59 AM
ghost civic
Jul 15, 2015 10:48 PM
