250 Blazer Mixture
Old Jan 25, 2004 | 03:56 PM
Sparkie's Avatar
Default 250 Blazer Mixture
When I got My 01 250 blazer the air screw was turned all the way in. I took it out 2.5 turns and it started bogging so I put it back in 1 turn. It seems to run ok now but I wanted to know what would hapen if I was running it to lean. Would it cause the engine to overheat or would it just kill the power? Any advice would be appreciated.
Old Jan 25, 2004 | 07:06 PM
xxxracerxxx's Avatar
running lean will make the engine over heat if there is not a enough fuel to keep the piston cool it may seize or melt a hole through it i have seen it happen it isn't pretty
Old Jan 25, 2004 | 07:23 PM
you will want to run a 14.7 ratio of fuel and air 14 parts air and .7 parts fuel 13.1 or 12.1 is also good[img]i/expressions/face-icon-small-wink.gif[/img]
Scooter's Shop
Oct 9, 2015 02:09 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
goosemasterkl
Aug 23, 2015 11:36 AM
Gnuters
Jul 19, 2015 10:03 AM
