Rebuit Rear Caliper Break-In?????
Old Jun 29, 2000 | 10:49 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
I rebuilt my rear caliper a day or so ago because the brake was not releasing on the rear brake (7 years old). The caliper is not sticking like it was but there is still a drag in the rear brake. The new pads are thicker and I am wondering if they need to break-in / seat themselves to the rotor???????
I put all new O-rings and piston in the caliper.
Brake line problem?
Adjustment?
Anyone that has rebuilt a rear caliper please let me know if you have experienced simlar results.
Chopper Bill what do you think?
Old Jun 30, 2000 | 10:07 AM
ChopperBill's Avatar
The rear brake has a mechnical linkage. Is it set up to tight? It should have freeplay.
Old Jun 30, 2000 | 10:09 AM
weedy's Avatar
That may be it. I will check that this afternoon. You said it should have alot of play??
I think the pedal (mechanical) is adjusted with very little play? I will check it first.
Thanks a million for the tip.
Old Jun 30, 2000 | 11:48 AM
Answered your post at home and didn't have the specs. Loosen the lock nut behind the **** on the caliper turn **** in till it meets resistence and back out 1/2 turn and tighten lock nut. I like to back out a little more for more free travel to asure it doesn't engage when it gets hot.
Old Jun 30, 2000 | 12:05 PM
weedy's Avatar
Chopper Bill you are tha man!
mywifesquad
8
Sep 21, 2015 08:20 AM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:57 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:48 PM
black_thunder
Sep 7, 2015 01:24 AM
snowolson
Aug 31, 2015 03:51 PM
