1997 Explorer water pump
I need help! My water pump is leaking on my explorer 400 4x4. I've purchased all the parts to fix it but I can't figure out how to get to the pump housing. Any help I can get will be much appreciated.
you will need to remove the counter balance shaft the pump is an extension of the right side of the balance shaft it may have bad seals
1994 sport 400 in the process of being rebuilt wisco piston ported cyclinder v force reeds dg race pipe weight removed cut fenders turf tamers
JMO, you might be better off purchasing a service manual to help along with this project, besides it will have pic's to help along.
Once you get the flywheel off, you will have to remove the balance shaft sump cover - the water pump housing is inside of here, attached to the inside of this cover, there are 3 nuts through the front of the sump cover holding the water pump housing to it. There is also a LEFT HAND threaded nut on the crankshaft that will have to be removed in order for the sump cover to come off
Here is a parts breakdown for a general idea: '97 400 water pump
exmotocrosser
Sep 13, 2019 06:12 AM
jrooker6
Apr 23, 2016 07:36 PM
BYC
Sep 25, 2015 02:10 PM
Sw00p
Sep 24, 2015 02:50 PM
