warn on 400 scrambler?
Old Jun 30, 2000 | 07:04 AM
Zman's Avatar
Just wondering if anybody ever put a warn winch on a 400? I know they are made for a Sportsman which has a 250 or 260 watt stator and the scrambler has a 150 watt.The winch draws 14-20 amps and this is my concern.
Old Jun 30, 2000 | 08:59 AM
Tree Farmer's Avatar
A winch at full pull draws 100 amps or more.
How does a winch motor draw so much current when an alternator produces so little?
The trick: the winch draws its current from the "storage" battery, not the alternator.
Don't worry about your electrical system's capability to support a winch; the battery's amp-hour rating alone paces the application (A 14 amp-hour battery won't power a winch at full pull for very long; hopefully, long enough to get you unstuck. If you draw the battery down, you'll simply have to wait while you charge it up again with the alternator. Good idea: keep the engine running while winching.).
Tree Farmer
Old Jun 30, 2000 | 01:32 PM
Zman's Avatar
Thanks,TreeFarmer I got a used winch and have been dieing to mount it on the scramber, I figured it would save my belt from burning up every time I have to pull someone out of the mud.
Now I can stay on shore and give them the hook instead.
Jeff Roper
Feb 1, 2022 11:48 AM
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
panicmanic
Sep 28, 2015 12:59 PM
exmotocrosser
Sep 26, 2015 08:18 AM
