sprockets
Old Jan 26, 2004 | 11:51 PM
POLARISFREAK's Avatar
Default sprockets
What sprocket seatup would be ideal sand dragging 300ft with the following mods ported intake tm45 on gas or alky, graydon pipe, rwr rev box. Also is it better to launch in second and then be to redline in 4th when crossing the 300ft mark, thanks for any input. Oh, running 22-11-10 10 paddle extreme haulers!
Old Jan 27, 2004 | 01:08 AM
QUADMAN650's Avatar
Default sprockets
14 tooth front people will tell you 15 all day long 14 the way to go stock rear
12 dolllars rockymouintainatv.com
Old Jan 27, 2004 | 01:43 AM
BlackHawk's Avatar
Default sprockets
I think he was talking about ideals, 15/42 is said to be most ideal, pretty much the same as 14/40 but a little better, so I'm told. 15/42 and you can still use the stock chain! (I think you can with a 14 tooth front as well.) The only bad thing I've heard about a 14 tooth front is that it supposedly causes extra wear on your chain.
Old Jan 27, 2004 | 03:05 AM
MRDS650's Avatar
Canadian and Proud of it !!!
Default sprockets
I agree with Blackhawk
I run a 15/42 set up and launch in second gear all the time. Same ratio and the 15/40 but you still get some top speed if you really wind it out.
Old Jan 27, 2004 | 03:12 AM
QUADMAN650's Avatar
Default sprockets
year and a half on my stock chain no unusual wearing for the holeshot 14tooth
Who wants to mess with the rear sprockets all the time it seems do be alot of work swapping the rear when you can get the same effect and cheaper cost just going to a 14 front
Old Jan 27, 2004 | 03:21 AM
BlackHawk's Avatar
Default sprockets
Yeah, I agree I didn't want to mess with the rear sprocket, however from eveything I've heard, 15/42 is more ideal than the 14/40. I went with the 15/40 for now, in the future I'm hoping the Lectron carburetor will put me back up at stock gearing with a whole lot more power. [img]i/expressions/face-icon-small-tongue.gif[/img]
Old Jan 27, 2004 | 03:56 AM
mystereid's Avatar
It's official, I've been duning for over 30 years.
Default sprockets
One of the things MRHP is doing is lightening the rear hubs for DS's, the reason? your motor has to spin this weight. An aluminum rear sprocket also take weight off for less money and probably more weight loss. 15/42 should be fine for flat sand drags. 15/43 has really done well on hill climbs but I've never tried the 42 rear. I run 14/43 now but it seems too low.
Blackhawk, get rid of your v paddles and get 22" 9 paddle extremes and then blow a whole $55 bucks on a rear sprocket it will gain you more than you will ever see from a carb or even $1200 worth of motor mods. And if you will notice I won't make a dime from this advice!!!
Old Jan 27, 2004 | 10:47 AM
ironrod's Avatar
Default sprockets
Whether you go 14 or 15 in the front really depends on your motor mods. If you have a really high strung engine, like a Ron Wood Stage II, then the 14 will be better. If you have more low end torque, like with the 14:1 piston, you'll want to change to the 15 tooth in the front. I just depends on your motor mods.
buddieboy
Dec 9, 2016 05:50 PM
merryman
Sep 19, 2015 03:15 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Old Deer Hunter
Sep 2, 2015 01:39 AM
Dammar
Aug 26, 2015 07:12 PM
