Blaster Help!!!!!!!!
Old Jan 29, 2004 | 09:49 PM
JerseyDirtDevil's Avatar
Default Blaster Help!!!!!!!!
Please help me out! I just recieved a Blaster, and the person I got it from decided to cut the wires for the TORS system. I know he cut them from both the throttle, and the TORS at the carb. but I can't find where they attach to. I'd much rather eliminate it if I can. Please tell me what has to be done with what wires, is there a kit to do this, on-line diagram, anything? If you have a link to any information about this please post that as well. Thank you.
Old Jan 30, 2004 | 12:09 PM
Shav0's Avatar
Im not exactly sure how to do it, but in the Blaster owners mannual it explains the whole thing pretty easily. See if you can get your hands on one of them because it will defently help you out.
Old Jan 30, 2004 | 06:13 PM
raptorblasterracer's Avatar
there is a kit to get rid of it idk where try rockymountainatv.com and vitosperformance.net
Old Jan 30, 2004 | 07:00 PM
420EX's Avatar
if I remember right, the wires at the carb dont need to be connected for it to run but the wires at the thumb throttle do.
Old Jan 31, 2004 | 01:57 PM
yfsrider's Avatar
yeah, vitos makes a kit. it gets rd of the entire pesky setup. you have to drill and tap a hole for the idle though. other than that it should be easy
Old Jan 31, 2004 | 02:17 PM
Blaster96's Avatar
I have not seen a Blaster for quite some time. But i did a home brew TORS removal. I simply unpluged the wires to the carb (that big blob on top of it), wire to the Thumb throttle (had to do that for my twist), and then i unpluged the TORS box under the front hood. Make sure you secure the loose wires so they dont ground out (use good electrical tape).
2 years after that, i bought a Carburator Cap from JR Gramm. ($20-30).
Old Jan 31, 2004 | 05:43 PM
quadrider4312's Avatar
get rid of the tors, there fu%#@ sh%#@ ok, get a tor eliminator kit
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
