Stock rev limiter and lowering kit questions
I have an 04 DS and would like to know if there is a lowering kit available to bring down the center of gravity. And if there is are they any good?
My DS is past the break in point............ when riding recently I hit the rev limiter a few times - I know this is what it's for, but does it damage it when you do hit it, or does it just keep the revs below a certain point without hurting anything?
Http://www.tbrproducts.com has a lowering kit and they are the best.
It's not that I ride that hard but I am looking for better handeling in the corners. I can always waster other quads in the straights but in the corners they seem to handle better. It seems like I have to try a lot harder to get through the corners. I was thinking it was a combination of the stock shock set up (too soft up front) and the high center of gravity. Any suggestions?
cain73 get a set of shocks first it will lower your lap times and help in the corners and whops. Too keep from hitting the rev limiter go up to a 17 tooth front sprocket. This will let you stay in any given gear longer and cut down on shifts
If I go to a 17 front won't I lose my bottom end ?
yes I have the kit and its great! the pic on the web site is mine. I run pep zep shocks with the kit all together I spent around $2900. well worth it, it turned my boat to a train (she's on rails).
