good deal??
Old Jan 31, 2004 | 06:13 PM
ineedtoride's Avatar
Default good deal??
i've been wanting to get some shocks, and i found some front 400ex TCS dual-rate, ZPS, rezzies with comp adj. and they're set up for a 160lb rider and stock a arms... i'm 150lbs, close enough, i think. he wants 400 plus shipping
hes sending me some more info and pics
thanks, guys
Old Jan 31, 2004 | 06:32 PM
2Fast4U400ex's Avatar
Default good deal??
if they are in good condition and nothing wrong it's a steal of a deal.
Old Jan 31, 2004 | 07:56 PM
Default good deal??
i got the pics and they look alright, but probably raced... still good deal?? i know its limited info, but...
Old Feb 1, 2004 | 02:11 PM
Default good deal??
hey, i just learned that if i get zps i will need to get a zps rear shock too. would this be worth the extra money, or should i just get limited mass or something like that?
thanks!
Old Feb 2, 2004 | 11:29 AM
thomez's Avatar
Default good deal??
ZPS is worth it but you are starting to look at quite a bit more money if you end up needing to ZPS your rear shock as well as the fronts. If you have the money it is great though.
Old Feb 3, 2004 | 08:49 PM
Default good deal??
thanks... what do you think the minimum would be to get all 3 at the same time (used, but not so used that they're junk) thanks again
Old Feb 3, 2004 | 09:50 PM
thomez's Avatar
Default good deal??
I don't know much about a 400EX but I assume the rear shock has a rezzie, no?
If so I am sure you can get it converted to ZPS through one of the major shock companies - I had an Ohlins converted to an Elka dual rate ZPS setup and with a revalve it was $325 - if you don't need it revalved it is quite a bit less cash.
Contact some places that service shocks and see what they can do for you.
So I'm guessing you can find some good front shocks for 400-500? and then maybe 200-350 for a rear conversion. Your mileage may vary.
lightninboy
May 16, 2021 09:52 PM
Frisky2050
Apr 9, 2020 11:19 AM
toonces
Oct 16, 2019 12:11 PM
coldnorthpol
Jul 14, 2015 11:22 PM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
