Belt Light Termination ?
Old Jan 31, 2004 | 10:08 PM
Kawi650's Avatar
Default Belt Light Termination ?
Ok My belt light came on.... NOW I want to turn it off how do i do that on a Prairie 700 A1? I think there's a white connector that I rotate 90 and turn the key on but not quite sure. Different from other kawis.
Old Jan 31, 2004 | 10:38 PM
Dangerous's Avatar
http://www.atvpower.com/folders/tech...0procedure.htmText
This will help.
Old Jan 31, 2004 | 11:26 PM
vtwiner's Avatar
Kawi, you already have enough hours on your bike to trip the belt light? WOW! I thought the 700 just came out a couple months ago. My light on the V just came on yesterday and I've had it since March. It must be nice to get out alot.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 1, 2004 | 12:29 AM
SpliffStar's Avatar
Hopefully this helps,
Late 2003 and 2004 700 Belt light reset procedure.
1. Turn the ignition switch OFF.
2. Disconnect both sets of 5 pin connectors located above the CVT cover. Note: These connectors are located just beneath the shift handle on the right side of the 650; one is black and one is grey.
3. Connect these 5 pin connectors to their opposite pairs (grey to black and black to grey).
4. Turn the ignition switch ON.
5. Disconnect the belt failure switch at the 2-pin connector above the CVT cover. (Note: Just follow the wires coming from the rectangular black box on the CVT Cover to locate this connector.)
6. Observe the belt-warning lamp. It should be flashing at a 0.4 second interval for a few seconds then start to flash slower. Let the lamp flash for at least seven seconds.
7. After seven seconds or more, turn the ignition switch off.
8. Reconnect 5 pin connectors to their proper location (black to black, grey to grey).
9. Connect the belt failure switch 2-pin connector (wires from CVT cover).
10. Turn the ignition switch on to confirm that the belt warning light is not flashing. Retry this procedure if needed. As far as I have heard it always works if the belt switch isn't tripped and there are no electrical problems.
Old Feb 1, 2004 | 03:20 AM
Kawi650's Avatar
Thanks going biking this morning and this will really speed up my day! LOL I don't know want was faster looking for what wires or limping home LOL. I think it was 51-52 hours and 1000km when she went to sleep. Man did it ever hit fast it was like using your kill switch. Vtwiner I had my 700 for just over a month. I'm out a lot less right now than normal because i have to work so much so "It must be nice to get out alot" my answer is it would be " it would be nicer to get out a lot more!"
fordfaithful21
Dec 7, 2015 05:52 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Logan Collins
Sep 5, 2015 08:03 PM
