What type of Fuel for p700?
Old Feb 2, 2004 | 04:30 PM
ropntoz's Avatar
Default What type of Fuel for p700?
what type fuel is recomended for the p700? any additives?
Old Feb 2, 2004 | 04:31 PM
VNASTY's Avatar
I run Super Unleaded in my V-Force.
Old Feb 2, 2004 | 06:26 PM
turbojosh's Avatar
93 octane is all i ever run nothing more nothing less.
Old Feb 2, 2004 | 06:36 PM
joechum's Avatar
u dont have to run as high as octane 93 yfz 450's run that it should tell you in your owners manual
Old Feb 2, 2004 | 06:39 PM
VNASTY's Avatar
Thats what the manual says to run![img]i/expressions/face-icon-small-confused.gif[/img]
Old Feb 2, 2004 | 10:48 PM
rutwad's Avatar
regular is enough for the P650. I feel like the 700 would have the same recommendation. Check your owner's manual.
Old Feb 2, 2004 | 11:10 PM
VNASTY's Avatar
IN THE MANUAL for KFX 700- page 36,it says min-87,use 91 octane.All we have is 93 octane around here.All the pro that run GNCC run 50/50mix 110&93 from what I have been told.
Old Feb 3, 2004 | 12:23 AM
crblick's Avatar
Running a high octane fuel(higher than 89) will give you no benefit what so ever. All that a high octane fuel does is take advantage of high compression, if your machine has higher than normal compression. If you are running on stock engine compression, unless your bike is a high performance bike out of the box like a YFZ, then regular gas will give you as much performance as 93 or higher.
A stock prarie will see absolutely no improvement from any octane higher than 89. All that running a higher octane fuel does is waste money because your engine compression can not take advantage of it.
Old Feb 3, 2004 | 12:44 AM
kawiyowee's Avatar
The P650 owners manual says the same as yours. If you go by the manual, you would use antiknock index of 87 or 93 which is the number shown on the pump of course.
Mine runs fine on 85, but I try to use 87. The manual also says you can use gasohol but to avoid methanol. Methonol is no longer sold around here.
Old Feb 3, 2004 | 08:28 AM
turbojosh's Avatar
I thought that 93 was a cleaner burning fuel than 87. I also think that it is not that much more i just don't like going cheap on my toys. Plus i run that fuel and alot higher octane in my cars and trucks.
TurboJosh
