250R axle carrier
Old Feb 3, 2004 | 05:03 AM
2StrOkeFReaK's Avatar
Default 250R axle carrier
How do you know when axle bearings are going bad??
Somthing is starting to squeek when going slow and its not the breaks.
Old Feb 3, 2004 | 07:21 AM
blue250r's Avatar
Hang the back of your bike up so as to get the wheels off the ground and try the axel for lift ie pull one wheel up and down if it moves at all the bearings are toast if not, remove the chain from the sprocket and spin the axel it should feel smoth and silent if not replace the bearings.
Dont continue to run it as if the bearings collapse the carrier and hub can be damaged big $
Order seals at the same time as the bearings as they aint expensive and will keep your new bearings clean and healthy, also pack as much grease as you can in the carrier. it will help keep water away from your new bearings
Happy spannering [img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 3, 2004 | 10:37 AM
steadyfreddie's Avatar
Just wanted to say that I very much agree with Blue's advice.
Old Feb 3, 2004 | 01:53 PM
Thanks, Ill do that. Whats up with those carriers with the grease fitting in the center. Do you
have to yank them out of the swingarm to grease them? How bout the ones with the grease
fitting on the side, seems like a long way for grease to go to get the other side.
I was thinking about getting a taper bearing carrier if my bearings are on the way out.
Thanks!
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
1000gade
Sep 9, 2015 04:41 PM
