Rim Size Help
Old Feb 3, 2004 | 02:33 PM
deautaronomy's Avatar
Default Rim Size Help
I just ordered xcr holeshots with the c series rims- But i had to go with the 20 11 10 rim size. The stock wheels are 20 10 9 . What will I lose or what will i gain whith the change.
Old Feb 4, 2004 | 03:44 AM
700quadman's Avatar
20-11-10 and 20-10-9 are tire sizes. In the first case (the new ones) the overall tire diameter is 20", width is 11" and it is mounted on a 10" diameter rim. Second tire is also 20" overall diameter but only 10" wide and mounted on a 9" rim. Since both are the same diameter, you won't see any difference in excelleration or top speed. The new tires are wider and lower profile so you will have a wider contact patch and less sidewall flex. You may notice those changes in hard cornering. Sliding may be a little harder to do...
-700 quadman
Old Feb 5, 2004 | 09:00 PM
Hey thanks Q man, I forgot about the width. Thanks again!!!
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
Levi Enstad
Sep 26, 2015 08:00 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
rgjackson
Sep 23, 2015 01:53 PM
Chasso
Sep 19, 2015 03:06 AM
