1 front wheel leans in the other is straight (chamber) Z400 stock A arms,why? what can I do/check?
Old Feb 3, 2004 | 10:46 PM
JOEYG's Avatar
Default 1 front wheel leans in the other is straight (chamber) Z400 stock A arms,why? what can I do/check?
Hi I just noticed that my right tire (sitting on the quad) is titled in more then my left tire which is straight, it is not much but it is noticable, what can I check to see if anything is bent? I don't think it is but I am not sure. thanks
Old Feb 6, 2004 | 09:35 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Check that both front shocks have the same amount of preload adjustment. If on is tighter, it could be lifting that side more than the other.
Old Feb 6, 2004 | 10:15 AM
BIG_RED's Avatar
The only thing I can think of besides what reconranger said is that you may have crashed your Z and twisted the frame. The previous owner of my banshee did this and now I have that same problem.
Old Feb 6, 2004 | 05:15 PM
Rudedog's Avatar
Have you hit anything hard with that side??? Check the upper A-arm and the upper ball joint on that side. They might be bent.
Compare all angles on "All" A-arms side to side. take your time. Sometimes you can see that one has a different angle IE: bent.
Rude Dog
KimSJoh
14
Jul 18, 2015 07:20 PM
jettman
Jul 6, 2015 12:16 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
yambam13
Jul 4, 2015 01:49 PM
Mphillips
Jul 2, 2015 07:20 PM
