1400 Idle Rpm on Rancher AT???
Old Feb 5, 2004 | 01:12 PM
rickytz7111's Avatar
Default 1400 Idle Rpm on Rancher AT???
I was wondering if you guys thought that 1400 Rpm is kind of high? I had mine set at 1400 and it just seems really high to me. I know this is what the manual recommends. What do you guys think?
Old Feb 5, 2004 | 02:23 PM
whatwasthat's Avatar
Nope, thats seems very normal to me. Its a one cylinder machine, if you had it much lower ,it would not run...
just for comparison, a 400ex idle is set at 1400rpm+-
Old Feb 5, 2004 | 04:04 PM
Maybe i'm listening to it incorrectly. But 1400 is correct I guess
Old Feb 5, 2004 | 06:50 PM
Rancherat400's Avatar
How can those of us tell if it 1400 RPM. Is there a way to tell by listening. I use to be able to set timing by listening when moving the distributor on a car. My Rancher AT sounds like it is barely ideling, but if I speed it up, it is hard to shift into forward or reverse.
Surely there is away to tell.
Old Feb 5, 2004 | 07:33 PM
If you really want to be absolutly correct.. you would need to get an aftermarket cdi with the correct output for wireing in a tach. Generally, all honda's come with the idle set at or near 1400.
If your valves are out of adjustment, this could cause the machine to have a rough idle, stall or poor performance. How many hours since your last adjustment?
franklyme
Oct 21, 2016 07:18 PM
rgjackson
Sep 17, 2015 11:21 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Minimod
Sep 10, 2015 09:20 PM
Minimod
Sep 10, 2015 08:03 AM
