2000 bomb with 5 hrs on it
Old Feb 8, 2004 | 08:18 PM
MentalState's Avatar
Default 2000 bomb with 5 hrs on it
I just bought a 2000 DS 650 for 3500 with 5hrs on it thing is Mint still has covers on stickers..I am new to this machine and have no Idea where to start as far recalls or upgrades...Any Info would be greatly appreciated...I will post some pics as soon as I can..
Old Feb 8, 2004 | 09:38 PM
SANDMAN430's Avatar
the roller on the chain is junk on the 00 -01 it's a 25 dollar fix
Old Feb 8, 2004 | 10:34 PM
MrMeaner's Avatar
Put a cdi on it and some good rear tires. Ron Wood racing makes alot of good stuff for them along with Alba sports.
Old Feb 9, 2004 | 08:44 AM
Thats it ?Rear tires CDI and roller for chain...Whats this I here about radiator fan...
Old Feb 9, 2004 | 08:57 AM
Well I took DS 650 that I purchased today for a beat run...Man she pulls hard..Funny thing was I put it in my garage and shut her down and could smell that new smell burning off and this thing is 4 years old...Thing is brand new kid never rode it just sat in his garage ?.Dont know how people can do this..I cant wait to get back on it...
Old Feb 9, 2004 | 11:16 AM
SANDMAN430's Avatar
the fan is a odd subject it will work and then stop the problem seemed to be they were to ridge of a mount and they would vibrate the wire inside loose. i've mounted mine with only two of the 4 bolts and now it runs all the time i've actually wired mine to a switch to turn it on when i want, but that is mainly for when i'm racing. seems there was a couple other recalls but nothing major the oil filter is one thing i would change the 01 went to a longer one and the change is just a new cover that is longer.
Old Feb 9, 2004 | 11:26 AM
fourlix's Avatar
If you don't mind spending a little money, changing upper A-arms will dramatically improve handling and get rid of the "twitchiness" or need for a steering damper. Some of the front shocks were overly stiff, but some were okay. The DS has had small but significant changes over the years. I'm on my third DS, I could have skipped the second, an '02 Baja, but I really like my new X. My '01 was great, but it needed the a-arms, shocks, fan.
What was the deal about the early models needing to have the oil pump primed after changing oil?
Old Feb 9, 2004 | 12:28 PM
BigWaynester's Avatar
when you change the oil you will have to bleed it, the screw is in there very tight, get the biggest screwdriver you got, maybe one with a square shank.
Check the toe , many were set wrong from the dealer, I think it should be around neutral to 1/8 toe out.
Unless you are running moto cross, if you get new tires, get 22" rear and 23" front, the 23"front helps keep the front end stable, cuts out some of the twitch at high speeds.
Old Feb 9, 2004 | 01:43 PM
MrMeaner's Avatar
My advice is to take one thing at a time. Even with the things everyone has listed its still the best quad out there to me.
1. Get an air filter
2. Roller
3. Longer oil filter and cover
4. CDI
5. Tires
You will find that there is always something to upgrade. The Forums are a great place to get ideas from people who have done them. The forum guys have helped me alot. Ron Woods racing has helped me alot along with Alba also. No question is a dumb question.
GOOD LUCK WITH YOUR QUAD I THINK YOULL LOVE IT.
Old Feb 9, 2004 | 01:44 PM
2Gordons's Avatar
For the roller, get an old skateboard wheel and 4 bearings. Works better than anything else, and alot cheaper as well. And, yes, bigger fronts make a big difference.
