How to clean the aluminum on ds650baja?
Old Feb 10, 2004 | 10:05 AM
Dragorus's Avatar
Default How to clean the aluminum on ds650baja?
I have been using Castrol superclean on my bike and I found it is tarnishing the aluminum parts.....How do we keep them shnig without alot of effort....and once they are clean how do we maintain them.....And also what should we use to wash our bikes to prevent this from happening again after we polish up the parts??
Thanx
Old Feb 10, 2004 | 10:24 AM
SANDMAN430's Avatar
as far as easy i'm not sure. iused that cleaner also and it turned my aluminum white. the local paint shop sells some liquid ruse polihing stuff it seems to work real well but it isn't spray on spray off it takes some elbow grease. after you get it back to shiney if you use it every cleaning it isn't to bad
Old Feb 10, 2004 | 10:37 AM
jiminok's Avatar
Fine steel wool and Mother's polish...some elbow grease and rags!
Old Feb 10, 2004 | 11:53 AM
JDsBusa's Avatar
Engine bright is what we used to use on the polished engines on custom harleys, and on street bikes with polished frames and such, I
have also used aerosol simple green for wheels. I would try them on one spot to see how they did before i sprayed the whole quad down.
Justin
Old Feb 10, 2004 | 01:37 PM
midLfinger's Avatar
castrol got a harley I used to ride. try MOTHERS mag and aluminum polish to get some shine back. The more elbow grease you put to it the more shine your gonna get.
Old Feb 10, 2004 | 02:06 PM
Dragorus's Avatar
I probably could whip it up with my dremel......
Old Feb 10, 2004 | 05:05 PM
Domi's Avatar
I use autosol or mothers polish and a drill with a buffing wheel. Dremil in tight spots. saves on my arms fallin off[img]i/expressions/face-icon-small-tongue.gif[/img]
Old Feb 10, 2004 | 10:33 PM
PureIntimidation's Avatar
Mine shines like chrome. Go to O'Reily's and buy some 3M heavy duty buffing compound, once you get that done really good, it will start to shine nicely. Follow that up with mother's, and whala! Chrome like shine![img]i/expressions/face-icon-small-happy.gif[/img]
Kenny
Old Feb 11, 2004 | 12:49 AM
MrMeaner's Avatar
Use Mothers and steel wool if bad and if real bad use steel wool and wd40. Then polish it with mothers. I also use Neverdull thats treated cotton in a can. It good to maintain the shine.
WilliamBos
Aug 8, 2015 07:26 PM
JohnnySplat
Aug 6, 2015 12:07 PM
WilliamBos
Jul 25, 2015 02:41 PM
Sandman2.0
Jul 21, 2015 09:03 AM
Dirtbikemike1
Jul 21, 2015 04:13 AM
