Rev Boxes?
Old Feb 10, 2004 | 05:07 PM
rancor's Avatar
Default Rev Boxes?
Are rev boxes safe to use. Do i have to change anything else if I get a rev box? does it hurt your Z in any way? is it worth it to get one?? just wondering what everyones opinions and experiences are.
Old Feb 10, 2004 | 07:34 PM
z838mx's Avatar
Default Rev Boxes?
just my .02 I dont think they are worth it on a stock motor if it is worth it at all. The stock motor loses power before it hits the rev limiter so what are you gaining by losing power in rs that you arent going to use anyway?
Old Feb 10, 2004 | 07:45 PM
lafngas's Avatar
Default Rev Boxes?
you might want to check a bit closer on this. I was told that part of the rev-limiting was for the box to start to retard your timing so it can't "hit" the rev control so hard. so with a aftermarket rev box it would let your quad have all the timing it needs to make power at a higher rpm. just a thought and again I do not know this for sure but it might be worth asking. Good luck
Old Feb 10, 2004 | 07:51 PM
z838mx's Avatar
Default Rev Boxes?
it does change timing you are right but not enough to compensate. the new vortex is a great rev box kind of expensive but well worth the money if changing your timing is your issue.
Old Feb 11, 2004 | 11:09 AM
rancor's Avatar
Default Rev Boxes?
Oh ok, i was just wondering, thanks for yalls help. Just trying to plan ahead. Im working on suspension right now anyways.
Joe454
Nov 20, 2020 01:19 PM
dannytas
Sep 26, 2017 06:31 PM
Whitelx1
Oct 2, 2015 10:55 PM
Sassinm1
Sep 30, 2015 04:23 AM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
