How can i make my warrior go faster without emptying my pocket?
How can i make my 1987 warrior go faster . I got a supertrapp pipe and that is about it. I want it to pull cat walks without popping the clutch. Thanx
Supertrapp
Supertrapp
Put Raptor plastic on it.
Sorry......that was Yamaha's thought.
I guess I don't know a lot about the Warrior, but opening up the airbox and rejeting is always good for a little more power.
a catwalk is when u lift the front end of the ground and drive. but it is kinda hard for me cause i am only 15 and i wiegh a 100 pounds.
87 warrior
supertrapp pipe
87 warrior
supertrapp pipe
and would i dyno jet kit improve anything???
supertrapp04
supertrapp04
No, jet kits are a waste of money, it is cheaper to just get single jets from your dealer. The only time you will see more performence with rejetting is when you change your intake or exhaust setup.
87 warrior
supertrapp pipe
87 warrior
supertrapp pipe
im 230lbs and can nearly do a cat walk on mine. pop the clutch and lean back. use the clutch and rear brake to adjust your angle.
