How can i make my warrior go faster without emptying my pocket?
Old Feb 10, 2004 | 06:38 PM
supertrapp04's Avatar
Default How can i make my warrior go faster without emptying my pocket?
How can i make my 1987 warrior go faster . I got a supertrapp pipe and that is about it. I want it to pull cat walks without popping the clutch. Thanx
Supertrapp
Old Feb 10, 2004 | 06:45 PM
Starky's Avatar
Put Raptor plastic on it.
Sorry......that was Yamaha's thought.
I guess I don't know a lot about the Warrior, but opening up the airbox and rejeting is always good for a little more power.
Old Feb 10, 2004 | 07:11 PM
And one more thing what size of jetting should i have and if a dyno kit would make a difference
87 warrior
supertrapp pipe
Old Feb 10, 2004 | 07:22 PM
AngryHampster's Avatar
147.5 main jet
50 pilot jet
drill 1" holes in 3 or 4 different spots on the air box lid.
sprockets can make it a good bit quicker, but take down top speed.
Warrior350ripper's Avatar
whats a cat walk_> i've heard it bebore but can't figure it out
Old Feb 10, 2004 | 08:11 PM
a catwalk is when u lift the front end of the ground and drive. but it is kinda hard for me cause i am only 15 and i wiegh a 100 pounds.
87 warrior
supertrapp pipe
Old Feb 10, 2004 | 08:13 PM
and would i dyno jet kit improve anything???
supertrapp04
Old Feb 10, 2004 | 08:26 PM
Crotts's Avatar
No, jet kits are a waste of money, it is cheaper to just get single jets from your dealer. The only time you will see more performence with rejetting is when you change your intake or exhaust setup.
Old Feb 10, 2004 | 08:37 PM
87 warrior
supertrapp pipe
100lbs = hard?! LOL
im 230lbs and can nearly do a cat walk on mine. pop the clutch and lean back. use the clutch and rear brake to adjust your angle.
Old Feb 10, 2004 | 08:41 PM
what do u mean about changing your exhaust setup?pipe? cause i have a supertrapp.
