How can i make my warrior go faster without emptying my pocket?
Originally posted by: supertrapp04
what do u mean about changing your exhaust setup?pipe? cause i have a supertrapp.
trust me, i just did it over the weekend. lol
and ya that popping the clutch but it is hard when i don't and that is wat i was talkin about, but i guess i didn't say that. I can pull a catwalk by popping the clutch but that balds out my brand new tires.
Originally posted by: AngryHampster
yes. also, drill some holes in the airbox lid, about an inch in diameter, allows for much more airflow, increasing the power noticably.
#15
Put it in the back of a pickup, cheapest way to go faster. Actually if top speed is what you want a tooth up on the front sprocket will give it to you cheaply. Other than that let the machine breathe, open the airbox up and pipe/rejet it. Next you have to go into the motor and it's $$$. To simply pull the front end up and ride wheelies takes no mods at all, just technique. Bump the throttle a few times in first gear to get the machine to rock and compress the front suspension. At the bottom of it's travel you nail the gas and she'll stand right up for you. You must then balance the machine and apply appropriate throttle to hold, keeping your foot on the rear brake so you can put the nose down if you get into trouble. Absoloutley free to do that!
#16
a catwalk is when u lift the front end of the ground and drive. but it is kinda hard for me cause i am only 15 and i wiegh a 100 pounds.
87 warrior
supertrapp pipe
87 warrior
supertrapp pipe
#17
#18
