Special tools for setting belt deflection?
Old Feb 12, 2004 | 02:40 AM
Customfabandweld's Avatar
Default Special tools for setting belt deflection?
36 miles on my Prairie, and the belt deflection is at 1 1/2 inches! Is that normal for the initial break in? ? Anyway, I was looking through the factory service manual and I saw the special tools that are needed to get the driven pulley apart. I plan to fab the tools myself, I was just wondering if anyone else had done the same, or are they just going to the dealer evry time it's needed.[img]i/expressions/face-icon-small-confused.gif[/img]
Old Feb 12, 2004 | 03:13 AM
rotty's Avatar
You can make the spring compressor with a piece of 1/2"x12" threaded rod, a couple of nuts, couple of washers, and a 2" threaded pvc cap. Drill a hole in the top of the cap and cut a notch out of the side and tighten the nuts to compress the spring and use snap ring pliers to take out the ring
Old Feb 12, 2004 | 09:53 AM
skun's Avatar
Yeah that's a good idea. I bulit my own secondary clutch spring compressor it look's very similar to the factory one. And it is very simple to make and works very good. The choice was easy for me because they are $275.00 plus tax in Canada. Good luck skun [img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 12, 2004 | 10:42 AM
RebelDS's Avatar
You cut a big notch in one side of the cap to get the pliers in, but it's also good to cut a small notch on the other side. That's handy to reach a screwdriver in the back side to work the ring back in place if it is finicky.
Old Feb 12, 2004 | 11:36 AM
OleManMoses's Avatar
If I remember correctly, type in NYROC spring tool, or something to that effect, and search the sites that come up---and if you cant find a link, with pictures and about an 18 page step by step procedure on making the tool and setting deflection, I will e-mail or fax to you
Old Feb 12, 2004 | 01:09 PM
eiger2's Avatar
How about the tool for pulling off the front pully? I borrowed the dealers but had to return it as soon as it was removed. They want like $45 for this bolt.
Old Feb 12, 2004 | 01:11 PM
RebelDS's Avatar
Try this one:
http://www.atvpower.com/Prairie%2065...0Procedure.htm
Old Feb 12, 2004 | 05:38 PM
kawiyowee's Avatar
No need to fab anything. You can buy the minor hardware for compressing the spring for ~$4. Then use a socket extension on the 27 pg atv power website (thank you author Nemmeh) to hold the torque of removing or reinstalling the nut.
I made the mistake of buying the tool used to hold the sheave against the nut torque because of the forum talk of air tools, which I don't have. Didn't fit, ~$90, worthless, can't return. No more dealer tools or parts for me if I can avoid it. Man, do they stick it to you.
Old Feb 12, 2004 | 07:53 PM
Raptor010101's Avatar
hey is the secondary 27mm nut a reverse thread ??????
Old Feb 12, 2004 | 08:55 PM
centerpunch's Avatar
No but the nut is crimped so it can be hard to remove. I used an electric impact wrench and it did the trick. I had to stay with it for a minute or so before it broke loose.
