help my buddies scrammy
Old Feb 15, 2004 | 05:31 PM
zag's Avatar
zag
Default help my buddies scrammy
My buddies scrammy 4x4 400 02 dosen't run to well the other day we were riding on the snow and all of a sudden it popped out of gear and and would not stay in gear had to hold his foot on the shifter to keep it from coming out of gear. After a while of that it just would not go back into gear and we had to tow him out. Any ideas on where we would start to look?[img]i/expressions/face-icon-small-blush.gif[/img]
Old Feb 15, 2004 | 05:46 PM
BigBadScrambler's Avatar
Sounds like the shfit linkage may need to be adjusted. Start with the easy stuff first
Old Feb 15, 2004 | 05:50 PM
zag's Avatar
zag
i don't think it that were else should i look. I think it may be more internal.
BT250racer's Avatar
hey big bad u know more upon this subject then i do jw though if it somthin to do with the trans wouldnt he here the gears griding when it switched and if it was a prob with the clutch he wouldnt here anything?
1999 250 trail blazer
k&n filter DG exhaust for now
just to make it a lil lounder
titan 489 xts on the back
maxxis razors on the front
full skid plate,bash gaurd
rebuilt trans,D.I.D chain
pro amor belt,scott grips
the newer model tie rod ends
12 t front 36 t back sprokets
neon shifter ****, pro burner lights
stronger back caliper holder i made at a friends shop
cut front fenders with the floor boards removed
makin aluminum dimond plate ones
Old Feb 15, 2004 | 05:54 PM
zag's Avatar
zag
Well i have been just told that yes there was some grinding happening.[img]i/expressions/face-icon-small-wink.gif[/img][img]i/expressions/face-icon-small-sad.gif[/img][img]i/expressions/face-icon-small-blush.gif[/img][img]i/expressions/face-icon-small-disgusted.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-mad.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-disgusted.gif[/img][img]i/expressions/face-icon-small-blush.gif[/img][img]i/expressions/face-icon-small-sad.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img]
Old Feb 15, 2004 | 05:55 PM
I would still check the linkage. I had my loosen up one time and it would pop out of gear into neutral. I had to hold it to keep it in gear. If it were the trans, I would suspect that you would hear the gears grinding
Old Feb 15, 2004 | 06:03 PM
zag's Avatar
zag
Will try it out tommorrow. Thanks for the help. I will keep you posted. Where are you from. Me and my buddies ride in the canadian rockies great place to ride if you can keep your quad running.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Feb 15, 2004 | 06:16 PM
ftwflh's Avatar
DITTO on adjusting the shifter
Old Feb 15, 2004 | 06:22 PM
quadwrench's Avatar
Here is a diagram to start with: 02 Scrammy 400 tranny.
Most of the time the popping out of gear starts with the shift rod not adjusted right (ie - not going all the way into gear) - then people try to hold it in gear and all the while the tranny is trying to jump out of gear - bingo the bellcrank (lever on top of the tranny - #11 on the diagram) starts to strip - thus not moving the shift shaft that puts the tranny in gear. These symptoms usually have gear grinding noises. These are easy, external fixes.
The only other time I have seen a polaris tranny not stay in gear is internal - the spring for the interlock pin (#14 in the diagram) had rusted to pieces and would not let the shift forks stay in position. The interlock is the snap (click) you hear when you shift the tranny in gear without the engine running - it locks the shift fork into a particular position. This tranny should be too new to have parts starting to disentergrate inside.
Try checking the easy stuff first.
Hack714
Oct 6, 2015 06:51 AM
Hack714
Sep 26, 2015 08:11 AM
Irishman301
Sep 23, 2015 01:47 PM
Hack714
Sep 20, 2015 05:54 PM
Canamaniac!
Sep 15, 2015 06:19 PM
