Polaris 700 EFI
Old Feb 16, 2004 | 04:16 PM
keeterskc's Avatar
Default Polaris 700 EFI
I am buying a 700 EFI this week. What is the biggest tires that I can install without any modifications. I am looking at installing either ITP 589's or Vampires??? Any suggestions. Also, is the 2 year extended warranty worth buying. All comments are appreciated.
Thanks,
Scott
Old Feb 16, 2004 | 05:58 PM
Catterman's Avatar
Got Milk!
Blaming Guns For Crime Is Like Blaming a Spoon for Rosie O'Donnell being Fat!
Let us know how you like the EFI! I really like (although I don't own any) the 26" ITP 589's. They would be great for that ATV. I would recomend the extended warranty. It is one of those things where if you buy it you won't need it, but if you don't buy it you will regreat it! Good luck.
Old Feb 16, 2004 | 06:02 PM
fidge1's Avatar
I suggest the 29 inch vampires-- you will have plenty of power to move them and they look sick
Old Feb 16, 2004 | 07:34 PM
bigbamaboy's Avatar
I have a friend with the 589's and he has liked them pretty well, if that is what your heart is set on. The 589's or Gators would be my choice if your planning on some hardcore mudding, but if you usually stick to mountain trails like me you could also consider Mudlites. With the 26's and up you get an inch&1/2 tread( I think) and they are much lighter than the other mudtires, therefor putting much less stress on your tranny. This is just a suggestion.
Old Feb 16, 2004 | 10:16 PM
Polaris500HO4x4's Avatar
if you would put on 28s you would need a life otherwise the tires would hit fenders and hard front impact
Old Feb 16, 2004 | 10:28 PM
BT250racer's Avatar
itp 589's all the way and they prob ride alot smoother on flat ground then the rest of them but im not sure.
1999 250 trail blazer
k&n filter DG exhaust for now
just to make it a lil lounder
titan 489 xts on the back
maxxis razors on the front
full skid plate,bash gaurd
rebuilt trans,D.I.D chain
pro amor belt,scott grips
the newer model tie rod ends
12 t front 36 t back sprokets
neon shifter ****, pro burner lights
stronger back caliper holder i made at a friends shop
cut front fenders with the floor boards removed
makin aluminum dimond plate ones
Old Feb 17, 2004 | 01:15 AM
BigD500ho's Avatar
Check out the Rubber on my Custom EFI @ the Link below!!
Old Feb 17, 2004 | 05:38 PM
markie's Avatar
You must be rich,that cargo box is cool, is the efi much faster than the other 700s.
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
maxjung
Jul 13, 2015 05:11 PM
