Water/mud damage?
u should check your trans and motor oil ever time u go in the mud check to see ifs a milky color and if it is change it you should also drain the crankcase and check for water in the air box and everwhere else. as for as how deep you can go in the mud ( my tb ) i can go up to the air intake for the clutch but after the water goes in there the belt starts to slip but if the intakes outs the water u can go up to the carb in water but its not good for your motor to let water in[img]i/expressions/face-icon-small-wink.gif[/img]
1999 250 trail blazer
k&n filter DG exhaust for now
just to make it a lil lounder
titan 489 xts on the back
maxxis razors on the front
full skid plate,bash gaurd
rebuilt trans,D.I.D chain
pro amor belt,scott grips
the newer model tie rod ends
12 t front 36 t back sprokets
neon shifter ****, pro burner lights
stronger back caliper holder i made at a friends shop
cut front fenders with the floor boards removed
makin aluminum dimond plate ones
Other than your regular maintenance schedule, you should check the fluids every time after you've ridden deep/muddy water - when they start looking a little milky - it's time to change - you've gotten water in. The biggest problem with the water/mud riders is that they don't think of checking/changing fluids until whatever craps out on them.
400H0
10
Aug 20, 2015 07:34 PM
