Will this Motor fit?
Old Feb 16, 2004 | 10:44 PM
Schweitzer's Avatar
Default Will this Motor fit?
Does anyone know if a 1996 Polaris 400 4x4 Scrambler Motor will fit on a 1996 Polaris Magnum 425 4x4 Frame?
Old Feb 16, 2004 | 10:54 PM
DGpolaris2346's Avatar
if it doesnt fit right just start cutting and welding and eventually it will work
Old Feb 16, 2004 | 10:56 PM
killerKXF's Avatar
it should fit with no problems...but if anything gets in your way cut it off.......
Old Feb 16, 2004 | 10:58 PM
Schweitzer's Avatar
That should work out, thanks for the replys.
Old Feb 17, 2004 | 10:33 AM
quadwrench's Avatar
I stuck a TB250 engine into a Sport 400 frame - it wasn't difficult, but a few mods had to be made - the biggest was clutch alignment as the 250's mounting hardware was located 3/4" different than the Sport frame. The exhaust and shifting rod had to be modified also, and you need to look at the wire connectors to make sure they will connnect up - and connect with the right configuration.
Old Feb 17, 2004 | 06:21 PM
mudmaster250's Avatar
why would u put a 250 engine in a 400 frame? im confused here
Old Feb 18, 2004 | 12:04 AM
quadwrench's Avatar
The engine on my SP400 tossed the balance shaft through the front - got the Sport 400 for peanuts - pulled the engine out of the Sport, slapped it in the Sportsman. Had an old TB250 that the tranny was junk - so, why not??
Just recently traded the bastard Sport even for a '95 Scrammy 4X4, rebuilt the tranny in it, stuck the clutches that originally came off the old TB to get it rolling - Well, I think I actually came out ahead putting the 250 into the 400 frame - don't you?
Old Feb 18, 2004 | 12:10 AM
i see your point then
EIF
Apr 20, 2017 07:15 PM
mrtidy
Feb 3, 2016 05:00 PM
kodiacrunner
Oct 4, 2015 11:52 AM
Whitelx1
Oct 2, 2015 10:55 PM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
