Cold Spark Plugs for DS650
Old Jul 5, 2000 | 11:29 PM
ScoobyDFW's Avatar
Has anyone tried a colder NGK spark plug? I read that they may be needed if you do a lot of high RPM riding. Also, I have had trouble reading the spark plug when the DS is hot. Either it is running slightly lean or the plug reading is false. If I check the plug after a real short ride through the first couple gears while the DS is still warming up, I get a much richer reading than when the DS is hot. Also, I tried those cheap & easy to get Champion 809 (RA6HC) plugs and I am suspicious that they are not the right plug for the DS. I would stick with NGK. www.ngksparkplugs.com
Old Jul 7, 2000 | 08:49 AM
KawasakiKid's Avatar
In my opinion, plug reading should take place after the machine has warmed up, and under normal riding conditions.
In regards to a cooler plug, that's not a bad idea, especially (like you said) if your burning 6000+ rpm's constantly (in the sand or whatever).
Old Jul 18, 2000 | 12:03 AM
ScoobyDFW's Avatar
In stock form I can't stand the bogging at less than 3500 RPM, so I always try to keep the RPMs up (I run a 38 tooth rear sprocket). I ride in Texas with 100+ degree temperatures. I installed colder D9EA plugs even though the stock DR8EA are a cool plug, and the DS is running a little better. I do still have a lean condition though with a K&N filter.
Big bousse
Sep 26, 2015 10:42 AM
cornermike
Jul 30, 2015 06:37 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
Bob Maurice
1) Engine problems..
Jul 14, 2015 09:05 AM
