Engine storing question!!
Old Feb 18, 2004 | 01:47 AM
bad350twin's Avatar
Default Engine storing question!!
I am currently in the middle of a total makeover of the rappy and was wondering if there is anything i should do to my engine while setting! (lubrication...etc)
Old Feb 18, 2004 | 02:04 AM
AlkyBurninX's Avatar
I use a product from belray called 6n1. Just spray it into the motor for long periods of storage. I have a couple sets of high dollar steel race heads for my truck that I put into a bag then spray a can of it in and it works great. This is the most awesome spray lube I have ever used. Try some.
Gold Eagle, the company that makes staybil, makes a spray that is just for storing engines. You start your engine then spray this in until it kills the engine. I have used it on jet ski's with great results. My dealer don't carry it anymore though.
Old Feb 18, 2004 | 02:19 AM
ryangibson's Avatar
If it is only going to be a few weeks or months, stored indoors, I wouldn't worry about it.
If it's going to be several months, pull the spark plug and pour one tablespoon of fresh engine oil into the cylinder, and turn the engine over a couple times BY HAND. This is to coat the cylinder with oil to prevent rusting. If you use the electric start, you will spray the oil all over. After you've manually cranked the engine over a couple times, install the spark plug. When you fire her back up in a few months, she's going to belch some serious smoke, and you will have forgotten that you did this and think your engine is blown. [img]i/expressions/face-icon-small-wink.gif[/img]
...Other than that, I'd change the oil so you aren't letting old oil varnish up in the block...
KimSJoh
14
Jul 18, 2015 07:20 PM
1966F100
Jul 12, 2015 03:08 AM
toonces
Jul 11, 2015 12:01 PM
200es
Jul 10, 2015 09:09 AM
D-Hagz
Jul 4, 2015 02:19 AM
