Bore a tb
Old Feb 20, 2004 | 11:23 PM
Trailblazinrider's Avatar
Default Bore a tb
I know i asked this before, but is boring a tb a good idea? It seems less expensive then porting. ALso, what sizes are there. It would be nice to have a tb 300 or 290. Just wondering?
NICK
Old Feb 20, 2004 | 11:34 PM
BigBadScrambler's Avatar
Default Bore a tb
Save your bores until you need them. You wont see much if any gains from just boring. You need other mods to see a difference.
Old Feb 20, 2004 | 11:39 PM
Default Bore a tb
o, that stinks, what other mods will make boring worth it? Thanks for the help man!
Old Feb 20, 2004 | 11:43 PM
Default Bore a tb
Porting will make the big difference. A bigger carb, milled head, then if you want throw a .20 Wiesco in there
Old Feb 20, 2004 | 11:49 PM
Default Bore a tb
kewl, thats what i was told before. Thanks for all ur help!
Old Feb 20, 2004 | 11:58 PM
Default Bore a tb
anytime bro[img]i/expressions/face-icon-small-happy.gif[/img]
Old Feb 21, 2004 | 09:36 AM
quadwrench's Avatar
Default Bore a tb
Like it is already said - boring is not going to make you much difference.
The formula is: [bore (mm) X bore (mm) X stroke (mm) X 0.0031416] / 4
Stock TB bore is 72mm - stroke is 60mm = 244cc's
Largest Wiseco piston for the TB is 74mm ( 0.080" or 2.00mm oversized)
bore 74mm - stroke 60mm = 258cc's
You havent' gained much (14cc's) by a maximum bore, and you have wasted a potential 6 top end rebuilds out of your cylinder.
Old Feb 21, 2004 | 01:40 PM
Default Bore a tb
oooo, that would not be good, i figured that i could go a lot bigger because i see all these 250rs with boring kits in the 300's. My bad, thanks for the help!
Old Feb 22, 2004 | 11:41 PM
mudmaster250's Avatar
Default Bore a tb
The big bore R's are all stroked. scott
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
Huntingdeer
Aug 23, 2015 12:06 AM
