jetting relative to cornering.....
Old Feb 25, 2004 | 02:31 PM
Flynbryan's Avatar
Default jetting relative to cornering.....
Question:
I have noticed after I changed my jetting it doesn't seem to pull as hard out of the corners. This is more as I'm making my "arc" in the corner, not at the exit under full acceleration. My question would be is this more needle related, or main jet related? I richened both, but am curious as to what circuit is affecting this performance the most in this instance. As always thanks for all responses.
Old Feb 25, 2004 | 02:39 PM
Randrball's Avatar
idle to off idle = pilot circuit
off idle to 3/4 throttle = needle
3/4 to WOT = main jet
hope this helps.
Old Feb 25, 2004 | 03:27 PM
hondabuster's Avatar
Check the float hieght.
Old Feb 25, 2004 | 03:53 PM
Flynbryan's Avatar
I'll check it out, but I don't think its the floats. It pulled strong through the mid-range before I adjusted the main and needle. I didn't touch the floats, unless I somehow bumped them by accident and got the adjustment off. I'll check into it though.l...
Old Feb 26, 2004 | 10:13 AM
Flynbryan's Avatar
Thanks for the responses guys. For anyone that happens to look at this in the future it was my needle being too rich that caused the loss in performance. I dropped the needle back to the prior setting, and it pulled like crazy again! Now I just need to get that stinkin' main jet sorted out....... [img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 26, 2004 | 03:21 PM
Youre going about it the right way. Change one thing at a time, and watch for symptoms, then adjust to get rid of them. Theres a list of symptoms at the end of this article.
jetting
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
caveeagle
Sep 19, 2015 01:20 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
