lem 50cc neemore power!
Old Feb 25, 2004 | 11:57 PM
bandit11's Avatar
Default lem 50cc neemore power!
[img]i/expressions/face-icon-small-mad.gif[/img]2001 lem 50 has no power. will not take off on any incline. Have checked for exh & intake restrictions "none found". dos'ent seem to whind out. Not sure where to go from here????
Old Feb 26, 2004 | 04:32 PM
racedad26's Avatar
Th only restrictors that are on lem quads are in the pipe right by the head intake, and of course the throttle gov. You might want to check your crank and piston yto make sure they are good. piston is easy just take top of head off and give it a look. You can see if your crank is bent by pulling the cover on the elec side and tour it and watch it as it goes by the stader to see if its moving further away or getting closer. you can change the gears and get more buttom end or top end also. I you want to spend some money there are a ton of aftermarket parts out there for your quad. you can email me if you want to maybe i can help. ill send you a p\m with my e-mail and phone
Old Feb 27, 2004 | 07:32 AM
bandit11's Avatar
[img]i/expressions/face-icon-small-happy.gif[/img]That would be cool, im a truck tech by trade but don't have much knowledge with quads. You said something about a throttle gov. "were do I find that?" my e-mail is firefighter1bert@aol.com any help would be greatly appreciated. I think the piston & crank are ok it runs great just lacks power. How do I tell if it might be the clutch?
Old Feb 29, 2004 | 10:56 PM
miniquadad's Avatar
If your in need of LEM parts try www.robbsracingengines.com hes got lots of stuff for them!
Old Mar 1, 2004 | 08:25 AM
bandit11's Avatar
her lem is already a 50cc, 10cc more will make that much of a difference? where do they put restrictions on these motors? Can i change the clutch or rear gear and if so what raitio should i try?
Old Mar 1, 2004 | 05:31 PM
racedad26's Avatar
The 60cc kit is a reed motor, tons of more power. the only restrictor is in the pipe. you said there was none there. rebel gears makes a sprocket for it. ac racing carries it[ mike marion]714-808-8330 we went to a 53 rear.
Old Mar 1, 2004 | 05:33 PM
racedad26's Avatar
sorry, action polini carries a 3 shoe that will fit that motor also they have one up on ebay now. go to motorcycles then parts and acc. then type in lem in the box.
Old Aug 8, 2004 | 02:31 AM
blukes's Avatar
check your main jet should be 65 mine came with a 60 in it .
the #65 made scoot and take off.worth checking you won't believe the differenc...
MeadowlarkFarm
Nov 27, 2019 08:40 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
byronman
Sep 6, 2015 06:34 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Logan Collins
Sep 5, 2015 08:03 PM
