sprocket size
Old Feb 29, 2004 | 09:20 PM
hondaguy2's Avatar
Default sprocket size
I put 20 inch tires on my 300ex if i put a 14 tooth sprocket on the front it will give me a little more top speed. Would it bring it back to stock speed and low end torque?
Old Feb 29, 2004 | 09:45 PM
Shav0's Avatar
smaller tire=smaller back sprocket.
one inch on the tire is the same as about 1-1.5 teeth on the rear sprocket.
Old Feb 29, 2004 | 10:17 PM
hondaguy2's Avatar
can't i just change the front sprocket?
Old Mar 1, 2004 | 06:34 PM
Hondanutcase's Avatar
Front sprocket is cheaper and easier. The only downfall is that one tooth on the front is equivalent to 2 - 3 teeth on the rear. Changing the front is more drastic, but it's a cheap enough mod to experiment with. I personally would not try to give a 300ex more top end by changing the sprocket because you will lose way to much bottom.
Old Mar 1, 2004 | 08:38 PM
Shav0's Avatar
its a give and take sisuation. If you add teeth to the front then you will loose alot of bottom end, and vice versa.
Old Mar 2, 2004 | 04:09 PM
Slacker1bob's Avatar
I would like to put a 14 tooth sprocket on my wifes 300ex, because it is way torquey, and first is almost wasted.
Old Mar 2, 2004 | 06:48 PM
hondaguy2's Avatar
thats what i have first gear you just hit the rev limiter right away and your not going very fast
buddieboy
Dec 9, 2016 05:50 PM
Levi Enstad
Sep 26, 2015 08:00 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
rgjackson
Sep 23, 2015 01:53 PM
merryman
Sep 19, 2015 03:15 AM
