Warrior Pipe Questions
Old Mar 1, 2004 | 06:59 PM
davis3340's Avatar
Default Warrior Pipe Questions
1. How hard is it to put on a complete pipe kit? I want like as complete a step by step description as you all can get.
2. Can I get a pipe that is as quiet or quieter than the stock pipe, yet still help performance or maintain previous performance level?
Im a complete neophyte to the whole sport quad arena and I know this is an ok machine to start off with and it has some possiblity for more power with the right mods, at this time im not completely into making it faster but i would llike to get the exhaust back to as quiet as stock. See I bought my warrior used and the previous owner took the baffle off. But anyways as i said im totally new to this so any tips or ideas on ways that you have made your warriors run better are much appreciated. Thanks for any help.
Old Mar 2, 2004 | 06:42 PM
superwarrior's Avatar
What kind of riding do you do. I have a FMF MegaMax II on mine. It's got a nice grunt sound to it. I put the Quit core in it to see what it would sound like and it's pretty quit. at least I think it was. It has good Performance.
Old Mar 3, 2004 | 05:04 PM
cRazyJ's Avatar
you may consider fmf q series increases performance and lowers sound by like 2 db
Old Mar 5, 2004 | 08:54 PM
HavokRacer's Avatar
its not hard at all to install a new silencer and header you should be able to handle it no prob. i dont think you will find a silencer that is quiet and has good perfomance though ( sorry ) it just dont happen but like crazyj said id look into the fmf q-core i an running a fmf megamax i hate the sound but the performance is good
Old Mar 8, 2004 | 11:29 PM
RAJ's Avatar
RAJ
FMF makes a good pipe, and so does alba. I have 2 buddies and they both have warriors and these pipes is what they got.
Old Mar 9, 2004 | 07:34 AM
NLWarrior01's Avatar
1. For a Warrior you don't need a complete pipe kit, just a slipon. The Warrior's stock header is fine until you start getting into serious engine (internal) mods.
Step 1. Loosen the retaining clamp on the intermidiate pipe (just below the reverse lever)
Step 2. Remove the two bolts which hold the muffler in place underneath the right rear fender
Step 3. Remove the muffler
Step 4. Put the new slipon muffler into place and re-install the two bolts
Step 5. Tighten the retaining clamp
It's just that simple.
2. Aftermarket pipes as a rule will be louder than stock. The quite core insert makes a big difference. My Warrior at idle and just light cruzing is barely louder than a stock Warrior, but when you are hard on the throttle it is quite a bit louder.
Good luck to you!!
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Backwoods_badass
Aug 27, 2015 11:23 PM
suzukiquadrunner1987
Aug 6, 2015 05:29 PM
Reactant
Jul 27, 2015 07:45 PM
