99 Xplorer not disengaging 4WD
Old Mar 1, 2004 | 08:31 PM
GST97's Avatar
Default 99 Xplorer not disengaging 4WD
I have a 99 Xplorer 300 4X4. It runs great except for sometimes after I have it in 4WD and I want to go back to 2WD, the front right wheel doesn't always want to come out. It seems if I stop, put it in reverse and back up a foot and then back into high it kicks out most of the time though. Sometimes it will kick out right away after I hit the button.
Would this be caused by low hub fluid or something?
Old Mar 2, 2004 | 07:55 PM
GST97's Avatar
anybody?
Old Mar 2, 2004 | 09:17 PM
quadwrench's Avatar
The first place to start would be hub fluid - when is the last time it was changed?? Could be caused by dirty fluid. Use the Polaris Hub fluid or a good synthetic ATF, and if they are real dirty, change the fluid several times after short rides ("stirs up" the "grunge") to clean it up.
Old Mar 2, 2004 | 09:28 PM
GST97's Avatar
I can use syntetic ATF also? I bet that would be cheaper than anything from Polaris [img]i/expressions/face-icon-small-smile.gif[/img]
As to the question of when it was last changed... your guess is as good as mine. I bought the machine about 5 months ago and havent done it yet [img]i/expressions/face-icon-small-wink.gif[/img]
Probably about time to change it [img]i/expressions/face-icon-small-smile.gif[/img]
What brands of synth ATF would you recommend? Or should I just go with the Polaris hub fluid?
MeadowlarkFarm
Nov 27, 2019 08:40 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
rockinkgin
Sep 25, 2015 01:52 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
Jason Richards
Sep 4, 2015 06:17 PM
