Air and fuel mixture screw?
Old Mar 4, 2004 | 11:50 PM
Haulinonthedunes's Avatar
Default Air and fuel mixture screw?
Is the air and fuel mixture screw located on the left hand side right in front of the filter mounts on the mikuni TM45 carb? Thanks Haulinonthedunes
Old Mar 5, 2004 | 04:46 PM
Hillbilly720's Avatar
That's right, clutch side right next to the filter...what pilot you runnin'? Got your accel. pump hooked up?
Old Mar 5, 2004 | 05:06 PM
My pilot is a 37.5. I dont know anything about this carb just got it yesturday and trying to find out stuff about it. What is the accel. pump and how do u activate it. Thanks Lance
Old Mar 5, 2004 | 05:55 PM
You will like this carb MUCH more with the accel pump activated. It's simply a plunger rod that you can see on the right side of the carb from the outside that dips down into the float bowl and squirts a little shot of fuel via a nozzle jet straight down the tubes. It's actuated by a white plastic spring loaded arm up by the throttle cable. If you have two plactic arms, one on each side of the top of the carb then you have the pump activated. If not, get a hold of Ron Wood for the kit (like$65) & install the #50 nozzle and adjust the squirt dutation for just a brief blast of fuel (not too long). BIG bottom end gains and you get rid of a certain "bog" that this carb induces beacuse of the 45mm bore, without the accel pump you get a big gulp of air and a "hiccup" of stumble right off idle when you crack open the throttle. Simply put, too much air all at once without fuel to follow soon enough.
Old Mar 5, 2004 | 06:49 PM
I understand some of that but the other u lost me. I see where the rod goes through that little hole on the right side of the carb down into the bowl. But what i cant figure out is that the metal thing where the rod goes into the bowl, does that stay in there or do u have to pull that metal piece out for the rod to go through. And also the plastic things u where talking about. I have one plastic thing where the throttle cable goes by the spring that makes it twist but there is not one on the other side. Sorry if u dont understand what i am talking about but i am trying to explain it the best i can. Will the fourwheeler still run without the accel pump activated, but it wont be as responsive right. What that means is that when you give it alot of throttle like if u are in a drag race it will bog when u hit the throttle but then the gas will catch up to the air and it will run fine, isnt that correct? Please let me know how this things is suppost to work because like i said i have no idea about this carb. Thanks
cdoren
Aug 16, 2015 11:22 PM
DanP24
1) Engine problems..
Aug 12, 2015 11:39 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
