Changing Clutch Springs?
Old Mar 7, 2004 | 10:29 PM
Haulinonthedunes's Avatar
Default Changing Clutch Springs?
I am changing to stiffer springs. I was wondering how hard it is to change them. Are they hard to get to when you pull your clutch cover off? How long does it take? Also i am not going to drain my oil i was just going to lay it on its side like put two center blocks under the two left side tires. I was just needing some info on if there is anything i need to know about while changing the springs or is it all a piece of cake. How hard is it putting the clutch cover on after u finish putting the springs in. Thanks alot Lance
Old Mar 7, 2004 | 10:41 PM
1BigDSRider's Avatar
Its not that hard at all. Remember to take your time and remove the pressure plate bolts alittle at a time to prevent warping the pressure plate. Soak the clutches in some oil. It takes about 30 minutes to change them.
Old Mar 7, 2004 | 10:49 PM
I dont understand. I have never done this before and dont even know what it looks like behind that clutch cover. I know there are 9 allen wrench screws holding the cover on, after i get the cover off what do i do next. If you could tell me step by step it would be greatly appriciated. Thanks alot for all the info. Lance
Old Mar 7, 2004 | 11:02 PM
Once you remove the clutch cover. The clutch basket is right in front of you. It has 6 bolts. Each bolt has a washer that holds the springs down. Each of the bolts needs to removed little by little. Once there removed you can pull the pressure plate off. behind the pressure plate are the clutches and metal fibers. One of the clutches has smaller tabs on it and is offset from the others. You will need to find it in your new clutches, it will go on last. You will pull all the plates and metal fibers out. Then replace with the new ones and replace the pressure plate and put your springs in. Tighten the bolts the same way you removed them little by little.
Old Mar 7, 2004 | 11:09 PM
Thanks but i am not changing my clutch plates just the springs. So all i have to do is remove the clutch cover then undo the six bolts with washers and but the new springs on and tighten all six bolts little at a time and but the clutch cover on and i am ready to go correct. Let me know if this is right. Thanks again for all the help. Lance
Old Mar 7, 2004 | 11:28 PM
Yes. Another thing that might help before removing the clutch cover, remove the front bolt holding the foot peg down. It got in my way so I took it out.
Old Mar 7, 2004 | 11:30 PM
arnold's Avatar
you should tighten the 6 bolts to specs and don't over tighten, you might need a new gasket on the case depending on the contition. try to do a search on the forum you will find lot's of exact procedures.
Old Mar 7, 2004 | 11:41 PM
I got a new gasket just wondering about the clutch springs. Do u have to take the six bolts off to get to the clutch springs?
Old Mar 7, 2004 | 11:44 PM
arnold's Avatar
once you take the cover off you will see and it will make sense the six bolts are the springs if you get me each bolt is held on seperatly.
Old Mar 7, 2004 | 11:53 PM
Thanks i understand now. I see u ported ur own intake. How does it do. I ported my own also but havent got to try it yet. I have a picture of it on my picture page. Let me know how urs did. Lance
ghost civic
Jan 15, 2020 07:43 AM
merryman
Jan 19, 2016 04:29 AM
ghost civic
Jul 27, 2015 03:15 AM
coolguy420
Jul 10, 2015 01:17 AM
Wnthunting
Jul 9, 2015 03:02 PM
