Dyno jet kit
Old Mar 10, 2004 | 10:01 PM
Bear4570's Avatar
Default Dyno jet kit
Will the Dyno Jet Kit for the Suzuki Ozark 250 work on the AC 250? The engines are suppose to be the same, are the carbs?
Bear
Old Mar 11, 2004 | 07:16 PM
CatKrazy's Avatar
you need to locate a oem parts finder website for the two bikes and comapre the carbs. if they are made the same yes, it will work. dyno kits are cheap, just oder one from Highlifter
Old Mar 11, 2004 | 08:46 PM
Bear4570's Avatar
CrazyKat; Well after some searching and then to confirm it, I call the dealer and the carbs are different(they handle both Suzuki and Cats). The Suzuki runs a Mikuni BS29, while the Cat has a Mikuni BST31. So no Dyno Jet Kit for my Cat. Guess I will start experimenting with needle settings first.
Old Mar 11, 2004 | 09:06 PM
CatKrazy's Avatar
sounds good, but first give us a little to go on. what goals are ya trying to reach as far as performance levels?
Old Mar 11, 2004 | 09:37 PM
Bear4570's Avatar
CraztKat; The bike works very well for me as I am over 50 and broke way to many thing over the years, including hitting a deer on my bike(motorcycle) in '94. Need to be able to get around the woods so I don't have to walk so much as the broken pieces give me grief. When we run logging road out here I have the smallest engine but have almost no trouble staying up with the big boys. However the bike has a mid range stumble on steep grades in 3rd and above gears with the throttle held wide open. If you back of just a bit the machine accelerates just fine but not as fast as it could. Besides it's not right and I like my toys to work properly. A little bit of power boost would not be looked down on either, but is not my prime desire. I don't mud run but we have to cross creeks once in a while, but usually never more than about 18" deep. Am planning on move the 24X9X12's to the front and putting some 25X10X12's on the rear for 1/2" more ground clearance and am aware the this will hurt preformance a bit, so the extra power would be nice. The snow get deep some times so every little bit of heigth helps. So far have gone everywhere the others have on one hell of a lot less gas and they all run 400's up to a couple of 700's.
Old Mar 13, 2004 | 02:52 PM
CatKrazy's Avatar
Ok i can go into great detail on this,but it would take alot of typing. What you need to do is on your search engine for whatever web browser you are using, Do a search for tex mudders site. Type it in just like that or texmudderssite. Once you find it,look at the menu tabs at the top. it explains in great detail with pictures on the car sytem. It will give you an idea on what you need to do.
good luck and if you have any questions send me a message.
CAT
Old Mar 13, 2004 | 09:45 PM
Andy Bassham's Avatar
www.ansley.net
easy to remember for me for some reason
Old Mar 13, 2004 | 10:56 PM
Bear4570's Avatar
Thanks for the info guys. Having been a certified marine mechanic for many years I had a pretty good idea of what to do, just needed some instruction to follow on this type of carbs. Never dealt with diaphragm carbs before.
Bear
Old Mar 14, 2004 | 12:15 AM
CatKrazy's Avatar
yep thats it!!! great info on there
also the diaphram carbs are a piece of cake. it will be a walk in the park for you!!
good luck
CAT
Old Mar 17, 2004 | 06:21 AM
Bear4570's Avatar
Did a shifter mod today, so while at it I pulled the top off the carb and move the E-ring up one notch to the second from the top notch to lean it out. Made it twice as bad. Then moved the E-ring to the fourth notch counting from the top and it doesn't stumble anymore, but seems to be a little more sluggish through out the RPM range. I guess I can live with it until I get a carb kit and check the float setting and make sure that the carb is clean inside. Does anyone have a recommendation for a fuel filter? I like fuel filters, I favor water-fuel seperator best. However not sure thats a good idea on a gravity feed system.
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
Cantbuytime
Aug 17, 2015 06:33 PM
EZRyde
EZ Ryde Exhaust
Jul 30, 2015 12:46 PM
BlackHawk
Jun 9, 2001 04:13 PM
