650 noise at idle fom belt
Old Mar 10, 2004 | 11:39 PM
NORYCE's Avatar
Default 650 noise at idle fom belt
The noise started as a chirping sound, the dealer said it needed a new belt due to it being loose They had to reset limp mode and never checked belt tightness, so I smoked the belt. After a new belt it still squeals. Any help?
Old Mar 11, 2004 | 02:40 PM
AC650's Avatar
You described my problem exactly. The dealer took a shim out and I have not had any problems since. I hope that helps.
Old Mar 11, 2004 | 05:56 PM
turbocoupe's Avatar
dont touch it! if its a light squeal or chirp its letting you know the belt is a little tight mine did the same thing and it still chips a little now . how you can tell if your belt is slipping etc is remove your storage lid and flip it over you will see belt dust there if very little dont worry, if its coverd like caked you got problems the belt in the 650 same as p700 is quite a strong belt dont believe everything you read or hear ,my moto is believe nothing that you hear and half of what you see
Old Mar 11, 2004 | 11:33 PM
NORYCE's Avatar
Even with a new belt, when at idle it sounds like a cat with it's poke stuck in the tranny. May be too tight?
Old Mar 11, 2004 | 11:40 PM
Cub's Avatar
Cub
Thats some good info on the belt dust on the bottom of the storage lid!! I was wondering what that was the other night and had no clue till now!!! Thanx a million! I am getting it serviced soon (100 mile service). The mechanic at the dealer is a friend of mine. He said he would put the primary and secondary springs in when he adjusts the belt!!
Old Mar 12, 2004 | 08:52 AM
homer's Avatar
Watching all the threads, I now have 80 miles on mine and I took it back to the dealer and had him to remove a shim as the engine braking I thought was a little weak. The belt now "squeaks" a little at idle, I'm going riding tomorrow so I will see how it does. I had saw in a previous post that if it has a slight squeak at idle that the belt should last a long time. The problem about the limp mode is what really scares me, I keep thinking about hitting a hill climb pretty hard and getting about 3/4 way up and it going into limp mode. Can't imagine that would be too pretty.
2quiker
Mar 22, 2022 08:36 PM
fordfaithful21
Dec 7, 2015 05:52 PM
Minimod
Sep 10, 2015 09:20 PM
Minimod
Sep 10, 2015 08:03 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
