lt 80 carb & clutch help
Old Mar 12, 2004 | 07:16 AM
QUADNUTT's Avatar
Default lt 80 carb & clutch help
[img]i/expressions/face-icon-small-confused.gif[/img]NEW TO THE FORUM, WOULD LIKE SOME ADVICE, JUST PURCHASED A LT80 OFF EBAY FOR MY DAUGHTER ,THE GUY TOLD ME CARD NEEDED REBUILT , I GOT IT HOME, SNATCHED CARB OFF MY SON'S $ FIRED IT UP, MOTOR SOUNDS GREAT,BUT IT WOULD NOT MOVE, I TOOK THE CLUTCH APART & ALL THE ROLLERS HAD FLAT SPOTS, NOT TO MENTION THEY WERE PACKED IN WHAT LOOKED LIKE HARD CLAY SO I CLEANED THINGS UP & ROLLERS ARE ON ORDER, I KNOW THIS IS BAD BUT WOULD THIS MOST LIKELY BE THE PROBLEM ?? I'M NOT EXPERIENCED WITH THESE CLUTCHES I'M NOT SURE OF THE YEAR, I THINK ITS A '90 . 2'ND ?? IS THERE A BETTER DEAL ON STOCK LT80 CARB KITS ,I JUST PAYED $35.00 AT MY DEALER FOR FLOAT " NEEDLE & SEAT". ANY HELP APPRECIATED , THANKS QUADNUTT
Old Mar 16, 2004 | 11:16 AM
LT80's Avatar
LT80 Expert
I've never bought a carb kit. I think the problem was in the rollers. I get machines in all the time with the grease hard (like clay). Look where the rollers go, usually the hub gets bad spots in it from the rollers sitting in one place. [img]i/expressions/face-icon-small-wink.gif[/img]
You should also take the rear clutch off and check the 2 bearings.
Old Mar 16, 2004 | 02:39 PM
QUADNUTT's Avatar
Thanks, LT80, Idid go ahead & order the hub when i ordered the rollers, it had wear like you said , my parts should be here today. On the rear clutch, I got as far the back half of the pulley part #2 on suzuki parts schematic, as to this is what I have been working from, "i'm still waiting on factory manual from dealer , 6 weeks now", the carb kit I was talking about was for replacement oem needles, seats etc. The only problem this quad was SUPPOSE to have was a flooding problem, bowl filling up, gas leaking out. My son's 88 lt80 did the same thing awhile back, I replaced the "float needle", & it's seat " about 35$$,it fixed the problem, but I still wonder if it was just the tiny O- ring that was bad,I didn't see any wear on that needle. Thank you for your input QUADNUTT
Old Mar 16, 2004 | 03:38 PM
LT80's Avatar
LT80 Expert
The fuel leaking problem can be learned at the "LT80 Petcock problem ARRRRRGH" thread. LOL [img]i/expressions/face-icon-small-smile.gif[/img] It may be a good read if the problem arrises again.
To check the rear clutch bearings, simply remove the nut and pull it all off. You can then use your finger to check the bearings. No rocket science here, just pay attention to how it comes apart. [img]i/expressions/face-icon-small-smile.gif[/img]
micheleLeigh
Jul 12, 2015 02:50 AM
Unzzy66
Jul 11, 2015 10:01 PM
200es
Jul 10, 2015 09:09 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
