Full POWER!!
Old Mar 14, 2004 | 12:11 AM
700EFI's Avatar
Default Full POWER!!
How long does it take to break in my 700EFI?? Seems to get more powerful every hour I put on it. Just wonderin'[img]i/expressions/face-icon-small-confused.gif[/img]
Old Mar 14, 2004 | 12:18 AM
Hozed's Avatar
probably a tank of gas or 2... make sure you change the oil after 1 hour... and then after another 5 hours or so... then change it about every 20 hours after that...
Old Mar 14, 2004 | 10:48 AM
Yellow650Rincon's Avatar
Read the owners manual it tells you the specified break in time. I think my friends manual said 20 hours for his EFI but I'm not positive on that.
It did say no full throttle until after 3 hours.
Old Mar 14, 2004 | 02:31 PM
PatsPolarisPage's Avatar
I think my 700 took about 300 miles. You could tell cause the throttle got snappy, and the top end was better. Remeber to go threw the RPM range with the throttle when breaking it in.
Old Mar 14, 2004 | 02:35 PM
fidge1's Avatar
Usual break in is about 200-300 miles or 20-30 hours of riding--- change oil after 3 hours and after 7 hours of riding also
Old Mar 14, 2004 | 05:24 PM
sneeker's Avatar
Ive got a new 700 efi the thing wount idle when cold it fOULS the plugs. IT'S been back to the dealer 5 times for the same thing It will start when it's cold but after about 5 cold starts it wount run and has to have the plugs changed. The dealer says they don't know what to do. It has 30 miles and 8 hrs of run time and there telling me i dont warm it up so thats 8 hrs and 30 miles how long do thay want a week to warm it up.
The thing get real bag gas mileage two tanks of gas in 15 miles. When it runs it's great no lag off start but not as fast on the top end as the carb type.
Im sorry i got rid of carb 700 for the efi... [img]i/expressions/face-icon-small-sad.gif[/img]
Old Mar 14, 2004 | 05:25 PM
sneeker's Avatar
Has anyone had trouble with there 700 efi fouling the plugs?
Old Mar 14, 2004 | 09:36 PM
95wolv's Avatar
sneeker,
If the quad fuel injection set up is anything like a car, maybe your thermostat is not letting the motor heat up enough, and it is staying in "warm up " mode, adding more fuel to warm up a cold motor. If it never gets to the correct temp, it will keep adding fuel, fouling plugs. Or, a coolant temp sensor could be bad, not letting the injection control computer know the motor is warmed up. Your dealer should be able to check these two things out.
Old Mar 15, 2004 | 07:51 AM
mtpockets's Avatar
hey Sneeker,
i noticed you changed States! your signature yesterday said kalamazoo, Nevada, and today it says Michigan!
what's up with that bro?
-MT[img]i/expressions/face-icon-small-wink.gif[/img]
STLyamwar
Jul 25, 2020 04:44 AM
Karas3434
Aug 3, 2015 09:17 AM
Jul 23, 2015 07:53 AM
Gtsordo
Jul 22, 2015 01:27 PM
tweeder
Jul 5, 2015 01:57 PM
