hey i have a question about a extended axel
Old Mar 14, 2004 | 05:36 PM
BlAsTinKid42's Avatar
Default hey i have a question about a extended axel
hey....i have a question about getting an extanded axel....would it be a good idea for ameture to get one...wat does it do?...i want to make my quad all racing..
yamaha blaster
nerfbars
new grabbar
skidplates
Old Mar 15, 2004 | 01:25 PM
maddog56's Avatar
ok. A longer axle will widen the bike and make it more stable both in the air and on the ground. It will also make the quad understeer if you dont widen the front. This can be done by flipping rims, getting offset rims, or buying extended a arms. with extended a arms, you should get new front shocks to compensate for the increased pressure. And bang, you have just spent 1500+ dollars.
In your case, a yamaha banshee axle will fit on your blaster. It would be much cheaper to buy one of these than an aftermarket axle.
Old Mar 21, 2004 | 03:57 PM
treylaxbanshee's Avatar
i disagree about the banshee axel thing, you should go ahead and spend the extra bucks and get a life time waranty with it, a stock banshee axel will run you $230 and a durablue eliminator will run you $290. you pick and choose, but he is right with other info.
bigred20653
Oct 2, 2015 10:05 AM
mark23
Oct 1, 2015 09:57 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
bigred20653
Sep 19, 2015 02:11 PM
greg86hd
Sep 16, 2015 12:32 AM
